radiator doesn't fit right (pics inside)
Old May 20, 2008 | 10:35 AM
obuhmyuh's Avatar
Default radiator doesn't fit right (pics inside)
bought a pep boys radiator (95 honda civic 1.5l) for my 95 del sol, but i could never get the damn thing to seat right and has been a pain in my *** for a year now, but i've just never gotten around to doing anything about it. any suggestions?
can post more pics, if need be.
Old May 20, 2008 | 10:38 AM
CivicSpoon's Avatar
You're missing the rubber "bushing" that goes between the radiator and the radiator support. Find one at a junkyard and see if that helps; it should.
Old May 20, 2008 | 10:41 AM
obuhmyuh's Avatar
Default Re: (CivicSpoon)
that goes between the foot of radiator and the actual chassis right? I didn't even know anything went there. Does it look similar to the ac radiator rubber bushing pictured right next to it?
Old May 20, 2008 | 10:42 AM
SinsEvil666's Avatar
i see a bushing right there for the AC support i think. try that bushing looks like it should be it.
Old May 20, 2008 | 10:49 AM
raidacaipo's Avatar
Default Re: radiator doesn't fit right (obuhmyuh)
you have to get rubber bushings for the bottom of the radiator.. then you gotta push it down and under the top metal frame.. its sitting way to high.. im suprise that your hoood can close..
Old May 20, 2008 | 10:51 AM
obuhmyuh's Avatar
Default Re: radiator doesn't fit right (raidacaipo)
it barely closes, i fabbed my radiator stay to get it to close right . there aren't any junkyards around my house in OC, maybe AZ, Kragen, or Pepboys ill stock those bushings.
Old May 20, 2008 | 10:55 AM
raidacaipo's Avatar
Default Re: (obuhmyuh)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by obuhmyuh &raquo;</TD></TR><TR><TD CLASS="quote">that goes between the foot of radiator and the actual chassis right? I didn't even know anything went there. Does it look similar to the ac radiator rubber bushing pictured right next to it?</TD></TR></TABLE>
I dont think that they are similar.. if I were you just go to a honda dealer and ask them for 2.. make sure you push it way down into the holes first.. then you push the top of the radiator down and under the top metal frame.. then bolt it down after its under it..
Old May 20, 2008 | 11:50 AM
obuhmyuh's Avatar
Default Re: (raidacaipo)
10-4 will do thank you
Old May 20, 2008 | 12:21 PM
raidacaipo's Avatar
See.. heres mine in the civic
LizbethDawn
Honda Civic (2001 - 2005)
May 9, 2013 08:23 PM
ej6hatchie
Jun 4, 2008 10:54 AM
aasaa666
Oct 22, 2007 08:15 PM
MugenT
Jun 3, 2005 03:23 PM
HondaRob
Jul 29, 2003 06:43 PM
