B17 Crank and VTEC Indicator
Old May 20, 2008 | 10:35 AM
C2K_TB_TEC's Avatar
Default B17 Crank and VTEC Indicator
Hi all, im a new member to honda-tech and have always read posts in this forum with great interest. I find honda-tech a great technical resource..
I have 2 questions:
1. Can a B17 crank b fitted in2 a b20 block?
2. Is it possible to connect a bulb or light to the VTEC solenoid, so as to indicate when vtec is activated? If so, any ideas?
Old May 20, 2008 | 12:01 PM
civicstar's Avatar
Default Re: B17 Crank and VTEC Indicator (C2K_TB_TEC)
1. yes but machining will need to be done, the b20 crank has a 89mm stroke vs the 87.2 i cant remember the exact number like that on the gsr.
2. yes you can wire it to a light like your CEL and there are how toos on the search
Old May 20, 2008 | 01:44 PM
silverblue888's Avatar
yes it's possible. try to look at my post. VTEC INDICATOR LIGHT. this may solve your problem
Old May 20, 2008 | 02:54 PM
mmuller's Avatar
Mad Scientist
Default Re: B17 Crank and VTEC Indicator (silverblue888)
-you can bolt in the crank but youll need custom made rods
-and as everyone said you can wire a LED to tell you when vtec kicks in
Old May 21, 2008 | 02:03 PM
C2K_TB_TEC's Avatar
Thanks for the replies guys,
I thought B17 crank is 81.4mm..
Then i guess will just get b16 crank for the B20.
I am looking to build a B20 with a rod / stroke over 1.7:1 so as to lower piston speed on the 89mm stock crank, looking to build a 9500+rpm N/A big bore monster.
I currently own a 2000 EK B20VTEC Turbo with arp.. dartons .. wiseco .. eagle etc etc..
454whp at 1.5bar (+-23psi) Turbonetics T3/T4 60-1
Thanks again knew i would get a response : )
Old Jul 20, 2009 | 04:32 AM
EG6 Master's Avatar
a B17 crank is 81.4mm and fits perfectly into a B20 block.
bossm
102
Jan 5, 2013 04:31 PM
amios
Aug 14, 2009 11:41 AM
ss396rat
Jun 5, 2009 11:03 PM
hybridpatient95
20
Jan 4, 2005 05:07 PM
hi-Powered
Nov 13, 2004 01:50 PM
