No need to set Ignition timing - fact or myth
Old May 20, 2008 | 09:15 AM
flanker's Avatar
Default No need to set Ignition timing - fact or myth
My 89 honda civic SI 1.6L – California model;
I have been told (by sources that were so-so reliable) that it is not necessary to adjust ignition timing since it is controlled by the ECU. However the shop manual (88 civic/crx) does show the procedure for checking/adjusting ignition timing. Have I been led astray? Does the ECU control the timing only within a marginal range?
Any facts would be much appreciated,
Ken
Old May 20, 2008 | 09:40 AM
accordaffair's Avatar
Default Re: No need to set Ignition timing - fact or myth (flanker)
set the timing with the ecu jumped, so the computer can't make changes. It can make timing changes itself, but you still need to set the base timing.
Old May 20, 2008 | 12:48 PM
sanimalp's Avatar
$cat /dev/urandom
Default Re: No need to set Ignition timing - fact or myth (accordaffair)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by accordaffair &raquo;</TD></TR><TR><TD CLASS="quote">set the timing with the ecu jumped, so the computer can't make changes. It can make timing changes itself, but you still need to set the base timing.</TD></TR></TABLE>
that is correct. the ecu can only adjust timing in a small +/- range of degrees.
an example would be if we assume the ecu can adjust +/- 5 degrees, then setting the timing to -18 means the ecu can adjust timing from -23 to -13. in this case, the base timing is set to -18. you can then see how messing with the base timing affects the ECU's ability to handle timing.
Old May 20, 2008 | 02:26 PM
JKingCivicSi's Avatar
With the ECU jumped? How do you do this. I tried adjusting the timing once but I did not know the ECU had to be jumped.
Old May 20, 2008 | 03:04 PM
thesmogman's Avatar
Default Re: No need to set Ignition timing - fact or myth (JKingCivicSi)
The ECU assumes the timing is set correctly. The ECU will not adjust the timing. It will advance it though, because it needs to.
There is a connector that you jumper that disables the computer so you can set base timing. It is a two wire connector that Honda put in different places to confuse us. It is either by the drivers strut mount in front of it by the motor mount, or to the rear of said strut mount by the injector resistor, or in the passengers side kick panel. However that said you don't really need to jumper it. If you just set it it will be close enough.
Old May 20, 2008 | 03:55 PM
flanker's Avatar
Default Re: No need to set Ignition timing - fact or myth (thesmogman)
This might be a dumb question but if the ecu advances the timing as needed, what harm is there by having the base timing off by a few degrees? Not that I would leave it that way of course.
Old May 20, 2008 | 04:01 PM
grog's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by flanker &raquo;</TD></TR><TR><TD CLASS="quote">This might be a dumb question but if the ecu advances the timing as needed, what harm is there by having the base timing off by a few degrees? Not that I would leave it that way of course.</TD></TR></TABLE>
The ecu will advance the timing to account for different loads, not for incorrect timing, It has no Idea where your base timing is, so it has no way to fix it.
Old May 20, 2008 | 07:49 PM
It can only adjust by a small amount as he said. If you're off by a significant amount, the computer won't be able to catch up.
Jump the mil code connector and set your timing.
If it isn't jumped, the computer may adjust the timing as you try to fix it, it will be working against you because it thinks something bad is happening. The distributor should generally be somewhere near the middle when set. If you have it advanced or retarded all the way just to get it regular you may be off a tooth.
Old May 22, 2008 | 11:14 AM
braass91's Avatar
Default Re: (accordaffair)
How do you jump the ECU and with what kind of wire? Does this wire come with the timing light kit? Thanks
Old May 22, 2008 | 01:31 PM
sanimalp's Avatar
$cat /dev/urandom
Default Re: (braass91)
I use a piece of solid copper wire i stripped the ends off. It is about 2 inches long or so.
Old May 23, 2008 | 09:02 PM
I use a paper clip bent into a U that I've kept in my glovebox for years
umair
Oct 16, 2008 10:34 AM
turbo-crx
May 18, 2008 02:13 PM
smash fascism
17
Sep 14, 2005 07:02 AM
Nextelbuddy
Mar 30, 2004 10:09 AM
infinate bound
Mar 18, 2004 10:35 AM
