don't tell me it's the headgasket
Old May 20, 2008 | 08:40 AM
G2_Fella's Avatar
Default don't tell me it's the headgasket
step by step: early this morning.
open up the radiator cap.
start engine.
no oil mix w/coolant, neither does reservoir
air bubbles blow out from neck of radiator
check exhaust; no white smoke
upper hose gets hotter faster than lower hose, eventually lower hose got hotter too
Note: car doesn't overheat driving around town. it only overheats when i go for a long drive like 2 hours or more.
t-stats been replaced twice and flushed out the coolant twice. new radiator cap.
what is the problem here?
Old May 20, 2008 | 08:42 AM
EkFG's Avatar
Default Re: don't tell me it's the headgasket (G2_Fella)
sounds like you have to bleed you coolant system. doesnt sound like a headgasket.
Old May 20, 2008 | 08:56 AM
G2_Fella's Avatar
Default Re: don't tell me it's the headgasket (EkFG)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EkFG &raquo;</TD></TR><TR><TD CLASS="quote">sounds like you have to bleed you coolant system. doesnt sound like a headgasket.</TD></TR></TABLE>that's one of the simple stuff that i don't know how to do. how do you get the air out? could you give me the step by step?
thanks.
Old May 20, 2008 | 08:58 AM
hpi247's Avatar
search for bleeding coolant. also, on you thermostat housing their should be a bleeder screw. take a 10mm socket/wrench, i believe, and slowly open the bleeder valve. a mixture of air and coolant may come out. be careful its very hot. i use some paper towels to catch the coolant as to not get it everywhere.
Old May 20, 2008 | 09:02 AM
CivicSpoon's Avatar
take off the radiator cap, and let the engine run. Occasionally rev the engine up a little bit (not enough to throw coolant all over the place). That's about it. Once you stop seeing air bubbles coming out for a while, it should be good.
If you have a bleeder screw on your thermostat housing, you can use that instead. You'd get a hose and some kind of clear container. Put the hose over the engine of the bleeder screw and stick the other end in the bottle. Start the car and let it heat up, then crack open the bleeder screw occasionally to let air out, close it again to build up pressure; just like bleeding brakes.
Old May 20, 2008 | 09:10 AM
G2_Fella's Avatar
Default Re: (CivicSpoon)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CivicSpoon &raquo;</TD></TR><TR><TD CLASS="quote">take off the radiator cap, and let the engine run. Occasionally rev the engine up a little bit (not enough to throw coolant all over the place). That's about it. Once you stop seeing air bubbles coming out for a while, it should be good.
If you have a bleeder screw on your thermostat housing, you can use that instead. You'd get a hose and some kind of clear container. Put the hose over the engine of the bleeder screw and stick the other end in the bottle. Start the car and let it heat up, then crack open the bleeder screw occasionally to let air out, close it again to build up pressure; just like bleeding brakes.</TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hpi247 &raquo;</TD></TR><TR><TD CLASS="quote">search for bleeding coolant. also, on you thermostat housing their should be a bleeder screw. take a 10mm socket/wrench, i believe, and slowly open the bleeder valve. a mixture of air and coolant may come out. be careful its very hot. i use some paper towels to catch the coolant as to not get it everywhere.</TD></TR></TABLE>
wow guys, that just sound so complicated. i hate messing with coolant/antifreeze and car battery.
i heard a simple way to see if you have a bad HG is, empty out the coolant in the reservoir and drive the car and rev it. if coolant flows in there it's bad?
is that a way to test it?
Old May 20, 2008 | 09:21 AM
G2_Fella's Avatar
i called to bullshit around a couple shops in town and they quoted me 35-45 dollars for a compression and a leak down test. each!
Old May 20, 2008 | 10:11 AM
hpi247's Avatar
Default Re: (G2_Fella)
haha i sound like you do when i first started my engine swap. people are cautious of what they do not know/understand. take a detailed look at your engine bay. see if you can print out a labeled picture and have fun educating yourself. its a good feeling working on your own car. you are able to say "hey, i did this". let alone save some cash.
2000eK_cIvIc
13
Apr 19, 2011 05:04 PM
nonvtec92
10
Feb 29, 2008 07:20 AM
Razr2
11
Jan 19, 2008 12:50 PM
CDtegGo
Aug 27, 2006 02:22 PM
IntegraTionR
Sep 18, 2005 08:22 PM
