H22 Turbo USERS. What gear do you end 1/4 with?
Old May 20, 2008 | 06:56 AM
95exdsmkilla's Avatar
Default H22 Turbo USERS. What gear do you end 1/4 with?
Just wondering, seems like my h22 tranny does not finish near 1/4 mile at all but dont want to go in 5th gear just because I might bog out.
Anyone else having same issues???
Old May 20, 2008 | 07:27 AM
md23vtec's Avatar
Default Re: H22 Turbo USERS. What gear do you end 1/4 with? (95exdsmkilla)
What's your slick size? Red line? Trans code M2F4?
Old May 20, 2008 | 07:57 AM
Default Re: H22 Turbo USERS. What gear do you end 1/4 with? (md23vtec)
24.5x8x13. yes it is m2f4 which is H22a1 tranny. My redline is at 8900.
Old May 20, 2008 | 10:01 AM
Mikey3000's Avatar
i finish near the top of 4th. 9300 rpm redline.
Old May 20, 2008 | 12:02 PM
Default Re: H22 Turbo USERS. What gear do you end 1/4 with? (Mikey3000)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mikey3000 &raquo;</TD></TR><TR><TD CLASS="quote">i finish near the top of 4th. 9300 rpm redline.</TD></TR></TABLE>
wat slicks are u using??? I really dont wanna go 5th gear lol. Anyone tried 4th gear from F22 tranny&gt;???
Old May 20, 2008 | 12:30 PM
OMG B16's Avatar
1 sec
Ok.
Tire size: 25"(or so with expansion)
Redline: 8900
And m2f4 gear ratios(M2F4 - 3.307 - 1.950 - 1.360 - 1.071 - 0.870 - 4.266)
You should be around 140-144mph at the end of fourth gear.
Modified by OMG B16 at 4:36 PM 5/20/2008
Old May 20, 2008 | 12:34 PM
DJsilkyjr's Avatar
your probably short shifting 1st gear, try bouncing off the limiter in 1st then shift second and see if that helps, mine was like that too until i took first gear a little higher.
Old May 20, 2008 | 01:09 PM
speedworks's Avatar
Default Re: (DJsilkyjr)
you can go to an h23 tranny and make it thru in 4th.
Old May 20, 2008 | 01:17 PM
Migrana's Avatar
Default Re: (speedworks)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by speedworks &raquo;</TD></TR><TR><TD CLASS="quote">you can go to an h23 tranny and make it thru in 4th. </TD></TR></TABLE>
Old May 20, 2008 | 04:52 PM
h22 civic's Avatar
true story
Old May 20, 2008 | 05:23 PM
Mikey3000's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95exdsmkilla &raquo;</TD></TR><TR><TD CLASS="quote">
wat slicks are u using??? I really dont wanna go 5th gear lol. Anyone tried 4th gear from F22 tranny&gt;???</TD></TR></TABLE>
i was using 25 x 8.7 x 13 M&H. my best 1/4 mile speed is 148mph in 4th gear.
Old May 20, 2008 | 06:56 PM
Turbo-charged's Avatar
i cant remember if i tried a h23 or an accord trans in my h22 hatch....but it was absolutely terrible lol
i'd use the h22 gearing and build the motor to hold some rpm...or better yet h to b
Old May 20, 2008 | 07:45 PM
Default Re: H22 Turbo USERS. What gear do you end 1/4 with? (Turbo-charged)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Turbo-charged &raquo;</TD></TR><TR><TD CLASS="quote">i cant remember if i tried a h23 or an accord trans in my h22 hatch....but it was absolutely terrible lol
i'd use the h22 gearing and build the motor to hold some rpm...or better yet h to b </TD></TR></TABLE>
The motor is built. 25psi on GT35R
H2b is sexy but I would like to stay with H22 tranny, kinda sux but I would like to make this 4th gear end @ 1/4 mile instead of no near the 1320...
Old May 21, 2008 | 04:20 AM
Mikey3000's Avatar
at what point on the track does your car top 4th gear?
Old May 21, 2008 | 08:02 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mikey3000 &raquo;</TD></TR><TR><TD CLASS="quote">at what point on the track does your car top 4th gear?</TD></TR></TABLE>
20-25yards away...
Old May 21, 2008 | 11:10 AM
Mikey3000's Avatar
can you get a lower final drive?
Old May 21, 2008 | 02:25 PM
speedworks's Avatar
the gearing is very close between the h22-h23. the accord trans could go through the quarter in 3rd.
Old May 21, 2008 | 03:13 PM
h22 civic's Avatar
Default Re: H22 Turbo USERS. What gear do you end 1/4 with? (speedworks)
swap your 4th gear for a longer one
Old May 21, 2008 | 10:59 PM
DLB1994's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by speedworks &raquo;</TD></TR><TR><TD CLASS="quote">the gearing is very close between the h22-h23. the accord trans could go through the quarter in 3rd. </TD></TR></TABLE>
Old May 22, 2008 | 07:13 AM
Default Re: H22 Turbo USERS. What gear do you end 1/4 with? (DLB1994)
I will be going to track soon once again. this time I will get in car video. that prolly would be more helpful to you guys.
AznBlueBoy
May 29, 2007 03:45 PM
.BigSexy
Sep 26, 2005 05:16 AM
meanEG
Nov 6, 2003 05:36 PM
lazy bum shaughn
Oct 22, 2002 09:04 PM
