can you reuse b16 head used on lsvtec
Old May 20, 2008 | 06:03 AM
97civic94gsxr's Avatar
Default can you reuse b16 head used on lsvtec
basically what the title says i have an ls/vtec setup right now and i'm having problems the vtec (oil pressure problem i think). my friend just got an s2k so he said he'd let me get his gsr motor if i wanted, and basically what i wanted to do was a poormans type r i already have the type r cams and intake manifold in my ls vtec and just wanted to throw my b16 head on his gsr block and was wondering if i would have problems with this because of the head being tapped.
Old May 20, 2008 | 09:18 AM
Default Re: can you reuse b16 head used on lsvtec (97civic94gsxr)
1/2 a day with a clear topic title and no one can help me ?
Old May 20, 2008 | 09:37 AM
Horizons1's Avatar
damn noob!!!! Use the search button
Old May 20, 2008 | 10:03 AM
gibsanez's Avatar
Default Re: can you reuse b16 head used on lsvtec (Horizons1)
What's so hard about taking the plug out of the hole that was tapped?
Old May 20, 2008 | 10:09 AM
pdiggitydogg's Avatar
And plugging the port on the back again?
Did you use GE relocation studs or did you drill for the dowels?
Old May 20, 2008 | 10:12 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Horizons1 &raquo;</TD></TR><TR><TD CLASS="quote">damn noob!!!! Use the search button</TD></TR></TABLE>
no **** moron i alread tried that why else do you think i made the topic why dont you up your post count somewhere else
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gibsanez &raquo;</TD></TR><TR><TD CLASS="quote">What's so hard about taking the plug out of the hole that was tapped?</TD></TR></TABLE>
well from what i read is when you tap the head you thread it till it stops to ensure when you put the male piece in it wont unthread itself i didnt do the conversion myself so i didnt know if i could just plug it.
Old May 20, 2008 | 10:15 AM
Default Re: (pdiggitydogg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pdiggitydogg &raquo;</TD></TR><TR><TD CLASS="quote">And plugging the port on the back again?
Did you use GE relocation studs or did you drill for the dowels?</TD></TR></TABLE>
i didnt do the conversion myself but i can take a pic of it and e mail it to you if you can help further i sure would appreciate it
Old May 20, 2008 | 10:47 AM
gibsanez's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97civic94gsxr &raquo;</TD></TR><TR><TD CLASS="quote">
well from what i read is when you tap the head you thread it till it stops to ensure when you put the male piece in it wont unthread itself i didnt do the conversion myself so i didnt know if i could just plug it. </TD></TR></TABLE>
What male piece are you talking about? It's a simple thread, it'll back right out unless you used loctite 262 or something stronger.
Old May 20, 2008 | 10:54 AM
I think he just means the threaded plug on the underside
krazeenoy
Apr 6, 2007 08:03 AM
B-JUSTINE
May 26, 2006 02:38 PM
firstgenrex
19
Mar 27, 2004 05:28 AM
LSHatchback
22
Jun 12, 2003 12:01 PM
spoon063
Apr 11, 2003 01:22 PM
