neo motor oil
Old May 20, 2008 | 12:07 AM
oreomilk's Avatar
Default neo motor oil
has anyone ever used NEO motor oil? or any experience with it?
cause i used to use it in my rx7 and it ran great also with the trans shifted like butter
but once i change the oil in my b20 swap it ran sluggish.
not sure what the problem is. but i can feel the power loss
compared to the regular mineral oil
any input would be great
Old May 20, 2008 | 12:08 AM
Eran's Avatar
HT White Ops
Default FV-QR
What weight did you use in your B20? Honda recommends 5w20 (previously 5w30) for all seasons, all temperature ranges, and for the life of the vehicle.
Old May 21, 2008 | 06:12 PM
oreomilk's Avatar
Default Re: FV-QR (Eran)
i'm using 10-30 weight that shouldn't really be the problem though? cause thats what i used to always use when i had my stock d16 and it ran fine
Old May 27, 2008 | 06:29 PM
oreomilk's Avatar
-_- anyone?
Old May 27, 2008 | 07:53 PM
SOHC_civic_si's Avatar
Default Re: (oreomilk)
I think the problem is bigger than oil. 10w30 synthetic weight should not be out preformed by conventional oil. just try like an amsoil 5/30 or something thats great oil and if its still sluggish then try a fuel system cleaning service to clean out all the carbon from your motor etc had could be causing your motor to be sluggish ( seafoam, etc. )
Old May 28, 2008 | 07:55 PM
oreomilk's Avatar
could it be the fuel filter?
Old Jun 2, 2008 | 05:46 PM
no
4LugR
Nov 13, 2006 01:59 PM
M.A.R.C.
Jul 9, 2005 08:57 AM
swlabhot
Jan 29, 2003 07:58 AM
