roll bar mounting plate screw up....
Old May 19, 2008 | 05:38 PM
logg_frogg's Avatar
Default roll bar mounting plate screw up....
Hey guys... I have a biiiiiiiig problem
I got a shop to weld in my roll bar for me and the dude cut my rear 6x6 mounting plates in 1/2 because he thought they fit better that way..... any suggestions on a fix??
Can I weld the sides on? or do I Hvae to cut it off the floor and slide another plate under??
Any suggestions??
..... I hate working away from home.....
Old May 20, 2008 | 06:08 AM
logg_frogg's Avatar
Default Re: roll bar mounting plate screw up.... (logg_frogg)
Anyone??
Old May 20, 2008 | 08:49 AM
FRernesto's Avatar
I know you are trying to find an answer ASAP what I would reccomend is giving a chassis shop a call try NRG they do cages all the time and see what they have to say. Good Luck!
Old May 20, 2008 | 09:03 AM
jjspec's Avatar
Default Re: (FRernesto)
You can bend the plates to make them fit better. The theory I believe is that one solid 6x6 plate will give you 36 sq in of area to keep the roll bar from punching a hole through the floor.
Edit: I just saw that it was already welded to the floor. Might want to call the regional NHRA tech inspector and ask. Sorry. Good luck with your build.
Old May 20, 2008 | 09:17 AM
AnthonyNYC's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by logg_frogg &raquo;</TD></TR><TR><TD CLASS="quote">Hey guys... I have a biiiiiiiig problem
Any suggestions??
..... I hate working away from home..... </TD></TR></TABLE>
First, it sounds like you just have a rollbar and not a cage, if that is the case I don't think you have to worry since NHRA only certifies cages.
And if you have a cage, you don't have to worry too much. Contact your local NHRA division office and ask the inspector directly. I just had my cage certified and they were more concerned about the quality of the welds and the thickness of the metal.
Anthony
Old May 20, 2008 | 11:41 AM
logg_frogg's Avatar
Default Re: roll bar mounting plate screw up.... (AnthonyNYC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AnthonyNYC &raquo;</TD></TR><TR><TD CLASS="quote">
Anthony</TD></TR></TABLE>
Yes it's just a Roll Bar, But i would still like it to be safe.
The plates are definetly 6x6 to ditribute the load to a wider area, thus preventing puncture.
My engineering background tells me that welding the peices back on should be fine as, if done properly, you will effectively have a 6x6 plate again.
As far as the quality of the welds I don;t have a problem at all! the welder was amazing, he just screwed up by cutting some of my plates instead of bending them &gt;.&lt;
eppymoto69
Jul 8, 2011 01:41 PM
spockeg
Oct 4, 2010 09:30 PM
90dxhmt
Welding / Fabrication
May 21, 2008 05:09 PM
illusion
Mar 10, 2003 11:43 AM
