Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
4x100 to 4x114.3 adapter?
Old May 19, 2008 | 02:50 PM
integraa972's Avatar
Default 4x100 to 4x114.3 adapter?
I just found a set of some minty fresh Blitz 01 wheels in 16x7 +42 & 16x8 +35 from a local for cheap but the bolt pattern is 4x11.4
I was thinking about purchasing some 15mm adapters to be able to ride with these wheels. how far will these wheels stick out with the adapters? or is it even worth buying the adapters and find some in 5x114 blitz wheels and swap over my 5lug that I have sitting around that I never got to install when I did my k swap
helppp meeee lol I plan on buying these pretty soon!
Old May 19, 2008 | 04:42 PM
EM2Brande's Avatar
Default Re: 4x100 to 4x114.3 adapter? (integraa972)
just wait till you do the Kswap, its better in the long run. As far as the flushness, it will be flush or slightly out enough to roll the fenders a little bit
Old May 19, 2008 | 06:27 PM
toyomatt84's Avatar
Sanji
Default FV-QR
The 16x7 +42's with 15mm adapters will need camber to clear the fenders, without a doubt. The 16x8's won't fit in the rear without extreme camber. And, I do not recall if the Blitz's have solid hubs or not, but if they do, 15mm will definitely not be big enough to clear the 4x100 studs. So, you'd need something like 45mm adapters to clear the OEM studs... which would make the wheels impossible to drive on. Either way, I wouldn't waste my time on them. Wait until you've done the K-Swap and 5-lug, to worry about wheels.
Old May 19, 2008 | 06:52 PM
yea I figured it will not be worth the headaches...
I am k swapped btw lol i just got lazy and never converted to 5 lug
apbtwhiskey
Mar 19, 2013 09:34 PM
EP-tree
13
Nov 26, 2009 12:10 PM
949
31
Oct 1, 2009 05:39 PM
