Built my first all motor car! post feedback!
Old May 19, 2008 | 02:28 PM
85mmEF4d's Avatar
Default delete
Modified by 85mmEF4d at 4:51 PM 5/19/2008
Old May 19, 2008 | 02:30 PM
Combustion Contraption's Avatar
Looks good. Good luck keeping negative comments out of this thread. Any pics of the head work?
Old May 19, 2008 | 02:31 PM
all-mtr-teg's Avatar
Default Re: Built my first all motor car! post feedback! (85mmEF4d)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 85mmEF4d &raquo;</TD></TR><TR><TD CLASS="quote">So after messing around with nitrous on several engines.
I decided to try this "N/A is best Route"
I started off with a b20b longblock. From there its history!
b20b bored to 85mm
RSmachine Dome top pistons
LS rods, balanced
b20 CRANK Micro/knife edged heavily
ITR oil pump
itr water pump
CTR pulley
For the headwork:
GSR head
3-angle valve job/pocket port
ITR heat coated valves
skunk2 stage 2 tuner cams
skunk2 pro valve springs
Aebs intake manifold
skunk2 composite fuel rail
RC 310 injectors
Erick's 70mm T/B
Skunk2 pro series cam gears
OEM timing belt
h22 LMA's
Hondata heatshield
Felpro HG
Chassis performance:
Skunk2Full Coilover's
Skunk2 FRONT & Rear Camber Kit
Full-Race Traction bar
Full-race radiator
UGR lower control arms (gold)
Integra front knuckles, 91 crx si Rear disc's With brembo rotors & poly inserts
Walbro 255l fuel pump
Engine Was Built By Collective Racing. Tuning done by Joe and locash.
Engine Boring and and Crank work done at Larrys Engine & Marine
Headporting was done by DOC's
All A/C & Heat components removed
12.2 CR
Engine made 212whp and 162 lbs tq on LOCASH Racing's Dynapack Tuned on 91octane, on ONE hot night
Chassis weighed 1860lbs with a 1/2 a tank,
For some pics:
Keep your negative comments to yourself
a link to the video of a 12.4 @110mph 1/4mile pass in PHX, AZ
http://vids.myspace.com/index.cfm?fu...deoid=29733463<U></U></TD></TR></TABLE>
This thread is gonna get locked, read the rules before you post
Old May 19, 2008 | 02:35 PM
85mmEF4d's Avatar
Default Re: Built my first all motor car! post feedback! (all-mtr-teg)
sorry, should of read first, not sure how to move a thread
Old May 19, 2008 | 02:46 PM
mar778c's Avatar
Community Builder
Community Influencer
nice job.
LsVtecEj1Milano
33
Feb 14, 2014 01:55 PM
JayDeeEmm
13
Jun 27, 2008 01:01 PM
85mmEF4d
Appearance Build Threads
19
Jun 3, 2008 06:57 PM
lsVman
Jun 16, 2005 07:39 AM
