has anyone replaced their power window motor before
Old May 19, 2008 | 02:22 PM
streetlights's Avatar
Default has anyone replaced their power window motor before
my driver side window wont roll down, so i took off my door panel and checked the switch which seemed to be okay, i also checked the fuse which was okay, so i guess i need a new power window motor for my driver side window...i was wondering if i could get some help from ht...the questions i have are:
1. how hard is it to replace the window motor and what do i have to do? is it just the four bolts holding it on the door panel that hold the motor in place? what else is connected to the motor?
2. where is the best place i can find a power window motor online?
thanks for your help
Old May 19, 2008 | 02:53 PM
SuckMyDOHC's Avatar
do you really need to double post in here and in the integra forum?
Old May 20, 2008 | 09:52 AM
Default Re: (SuckMyDOHC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SuckMyDOHC &raquo;</TD></TR><TR><TD CLASS="quote">do you really need to double post in here and in the integra forum?</TD></TR></TABLE>
do you really need to post this?
if i didnt need to post, i wouldnt have...sometimes i get better info in this forum, if you dont like the post just ignore it...its not like ive been bumping it up...
Old May 20, 2008 | 05:23 PM
Jdm_jay's Avatar
Default Re: has anyone replaced their power window motor before (streetlights)
its not hard to replace, its 4 bolts and one connector. the best one ive used has to be the factory honda one if u can find a good used one great, dont really trust the quality of a aftermarket motor. good luck.
Old May 21, 2008 | 10:28 AM
Default Re: has anyone replaced their power window motor before (Jdm_jay)
thanks
it seems pretty straightforward, is the motor holding the window up or anything like that?
Old May 21, 2008 | 03:41 PM
01-0720's Avatar
i replaced mine about 2 years ago, its super easy, its pretty self explanitory once you get the pnael off etc, you gotta remove the track and the motor is attached to the track, but the track does hold the window up, theres 2 little tabs on the bottom of the window that attaches to the track, there kinda glued/stickied on, be carefull pulling it off the window
and remember when you reinstall dont forget to re glue the window back onto the attachment points on the track or it will fall out of the track when you rol the window down
Old May 21, 2008 | 04:39 PM
sheekdude's Avatar
Default Re: has anyone replaced their power window motor before (01-0720)
Sure its easy as changing a light bulb... pm me if you want one. i have one at the junk yard where i work.
Old May 21, 2008 | 05:05 PM
00-501itrspec's Avatar
Default Re: has anyone replaced their power window motor before (sheekdude)
HAHAHAHA look !!!!!!
Thats is ME on the floor!!!!
Yea , me and Joel( sheekdude) Fixed My window in a mall parking lot !!
I put the motor on myself the day before , and i guess either I did it wrong , ( i don't think so )
OR the bolts backed out .
Either way , Joel basically did it again the day after because hes the man , and my hands were all messed up from doing it the day before , and hes the man
I think there's one spot that has a certain size bolt there , and the rest are different , and that's why it backed out on me , I believe .
Basically just be careful with which bolts go where .
It is a pain in the *** To get the the window in the slot correctly , but when it is , you will know its in right , that's all i really remember .
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sheekdude &raquo;</TD></TR><TR><TD CLASS="quote">Sure its easy as changing a light bulb... pm me if you want one. i have one at the junk yard where i work.
If you have any questions ask Him , maybe if you toss him a few bucks , he might help ya or do it for you i dunno I would (EDIT: But i see your in cali )
PM me or sheekdude if you have any more questions
Old May 22, 2008 | 09:07 AM
Default Re: has anyone replaced their power window motor before (00-501itrspec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 00-501itrspec &raquo;</TD></TR><TR><TD CLASS="quote">HAHAHAHA look !!!!!!
PM me or sheekdude if you have any more questions </TD></TR></TABLE>
thanks dude
thats why i still use this website, or post in this forum...theres still good help around
GsRrrr
Jun 14, 2011 04:02 PM
si_motor_spt
Honda Civic (2001 - 2005)
14
Jul 12, 2010 01:37 PM
streetlights
Dec 5, 2008 10:06 AM
kings1ey
Jun 20, 2005 02:55 PM
Gennady
Jun 18, 2002 05:23 PM
