has anyone replaced their power window motor before?
my driver side window wont roll down, so i took off my door panel and checked the switch which seemed to be okay, i also checked the fuse which was okay, so i guess i need a new power window motor for my driver side window...i was wondering if i could get some help from ht...the questions i have are:
1. how hard is it to replace the window motor and what do i have to do? is it just the four bolts holding it on the door panel that hold the motor in place? what else is connected to the motor?
2. where is the best place i can find a power window motor online?
thanks for your help
is not that hard.. i believe thers 3 screws!
all u need to do is unbolt the 2 scews thats holding the winow , k i made some example on the pic what u sould unbolt and wher
Black-Unscrew them from the door
Red-uneed to take this one out that way u can separate it from the glass
Blue-is the motor
Yellow-Now all u need to do is unbolt those 3 screws to take out the motor then when ur done put everything back.. oh dont forget to remove all the harness from the motor etc.. You can buy motor from ur local craigslist or ebay.. hope this help
Modified by JDMDC2BOY12 at 4:10 PM 5/19/2008
Blue-is the motor
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TeaAddict »</TD></TR><TR><TD CLASS="quote">i think team-integra has a write-up on it. check articles</TD></TR></TABLE>
i couldnt find the article on team integra...can you post a link?
how do you "jump the switch"
when i press down on the driver side switch i hear a click, so i thought the motor must be bad, and not the switch?
not necessary...my windshield wiper switch click but doesn't work...
you can jump the switch by connecting the wires directly that go into it...
get a schematic from a repair manual to find out which one and replace fuse for the hell of it
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shadohc »</TD></TR><TR><TD CLASS="quote">I am having the same problem do you have to take the window out of the door</TD></TR></TABLE>
its easier if you take it out..
si_motor_spt
Honda Civic (2001 - 2005)
14
Jul 12, 2010 01:37 PM
streetlights
May 22, 2008 09:07 AM
