Sensor Id and placement on this manifold..Please.
Old May 19, 2008 | 01:27 PM
zaxfire69's Avatar
Default Sensor Id and placement on this manifold..Please.
Hi guys. Don't know if you guys know or not, but I am swapping out my D16y7 for a zc sohc non vtec. Which in Japan is a d16y7...Ok I have this sensor that I have no clue where it goes or how to hook it up on this manifold. The manifold is the one that came with the motor from Japan. I have enclosed some pictures and hopefully you guys can help me...Also where is a good place to get a 3 wire throttle position sensor for the above manifold Fast.....
This is the sensor off of the Y7..Denso 136200-1290 pcs4 IS THIS THE EVAP PURGE Solenoid???? If so do i need it?? If I do where do i connect it on this intake???
I need to know how to put it and what to hook it to on this manifold. You can see where my TPS sensor should be..IT BROKE>
Top view of manifold....
I am so close to having everything in...I just need your help to get it in....THank you. guys...
Modified by zaxfire69 at 2:39 PM 5/19/2008
Modified by zaxfire69 at 2:48 PM 5/19/2008
madcrossover
Feb 12, 2007 08:03 PM
str8JDMteggy
Oct 23, 2006 12:57 PM
redintegra1998
Jul 14, 2005 10:43 AM
