damn, what is the problem? (overheating situation)
Old May 19, 2008 | 08:32 AM
G2_Fella's Avatar
Default damn, what is the problem? (overheating situation)
took my car out for a test drive yesterday. wanted to see if my car would still overheat. same problem again. i replaced the t-stat twice and flushed out the coolant twice. car still overheats. let the car cool down for 30 mins and added water and on the way back home car did not overheat. can somebody give me the simple answer and tell me it's the "radiator?" i still doubt it's the radiator cus i see no leaking? what else could it be?
i almost got stranded in the IE yesterday. scary **** to be stranded out there alone. before the central cali trip i replaced t-stat and flushed-overheated on the way home. yesterday to the IE-overheated on the way there. what is going on?
Old May 19, 2008 | 08:36 AM
curtis95dxt's Avatar
Default Re: damn, what is the problem? (G2_Fella)
if the radiator came off or a car that a head gasket blew or a sleeve cracked it can blow all the finns that the water flows through out and pinch the fins that air flows through closed blocking all the air flow. or your water pump impeller is coming apart or something. has it ever had green and orenge coolent mixed together?
Old May 19, 2008 | 08:40 AM
G2_Fella's Avatar
Default Re: damn, what is the problem? (curtis95dxt)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by curtis95dxt &raquo;</TD></TR><TR><TD CLASS="quote">if the radiator came off or a car that a head gasket blew or a sleeve cracked it can blow all the finns that the water flows through out and pinch the fins that air flows through closed blocking all the air flow. or your water pump impeller is coming apart or something. has it ever had green and orenge coolent mixed together?</TD></TR></TABLE>i'm a lil lost from your saying. what you mean by "radiator came off?" since i bought the car 2 years ago i've never replace the radiator and it has been flushed out a total of 4 times. never had a orange coolant put in there before.
so you're saying it could be a head gasket?
Old May 19, 2008 | 08:45 AM
King V's Avatar
Take the car to a power car wash and blast out the fins on the radiator first before you replace the radiator for no reason and make sure its "burped" of all the air you can get out of it.
Old May 19, 2008 | 08:56 AM
G2_Fella's Avatar
Default Re: damn, what is the problem? (King V)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by King V &raquo;</TD></TR><TR><TD CLASS="quote">Take the car to a power car wash and blast out the fins on the radiator first before you replace the radiator for no reason and make sure its "burped" of all the air you can get out of it.</TD></TR></TABLE>
sorry for my ignorancy. but what is a fin? and where is it at? is it the fan or you talking about the big filter in front of the radiator? it sucks not not knowing a whole lot about this.
not sure about the san fran trip if its being like this. i don't want to be stuck and on the side of the road.
Old May 19, 2008 | 08:58 AM
G2_Fella's Avatar
if a new radiator can solve this problem, then i don't mind puttin out another 120.
Old May 19, 2008 | 09:07 AM
G2_Fella's Avatar
i've done some search...most people's car overheat when idling or regular freeway or street driving.
my car, overheats when i go on long road trips? wtf? it doesn't overheat to and from work or just regular driving around town.
Old May 19, 2008 | 09:16 AM
G2_Fella's Avatar
i was looking to get bright answers from my fellow ht-tech- so far i've gotten nothin.
went to justanswer.com and they wanted $ to just answer questions. man i can't believe this.
Old May 19, 2008 | 10:02 AM
hondateg10's Avatar
From: Somewhere in the United States, united states
Default Re: (G2_Fella)
ok lets see if i can be a little help since i had this happen to me. I have a 95 hatch and everything was fine until i put a b18 swap. burped it(meaning getting the air out the system) then i started overheating but never would reach all the way on hot.
i took my t-stat out and left it out for the time being and gauge would get about half
so i tried to bleed the air out by the valve(upper radi hose where it goes to the head) and then my gauge would read about half and would stay about half. i still wasnt happy with that reading
so i bought a dual core radi and replaced mine. performed all the steps over and made sure i got all the air out of the system
now i dont even get 1/3 most the time.
Old May 19, 2008 | 10:12 AM
h2392si's Avatar
Default Re: (hondateg10)
Try replacing the fan swith, radiator cap, new radiator, fan relay, water temp switch, waterpump, etc. you can replace many things you dont have to if you're not careful. You might have to take it to a mechanic to tell you what to do if you have that little knowledge. A new radiator for your car is 32$ shipped from ebay, FYI.
Old May 19, 2008 | 10:14 AM
G2_Fella's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondateg10 &raquo;</TD></TR><TR><TD CLASS="quote">ok lets see if i can be a little help since i had this happen to me. I have a 95 hatch and everything was fine until i put a b18 swap. burped it(meaning getting the air out the system) then i started overheating but never would reach all the way on hot.
</TD></TR></TABLE>see how the problem is solved? NEW RADIATOR! did you have any leaks on your old one? i might as well try these steps and go DUAL!
f-ck it, leak or not i'm buying a new radiator.
thanks man!
Old May 19, 2008 | 10:18 AM
hondateg10's Avatar
i think what my problem end up being was my radi wasnt holding pressure
Old May 19, 2008 | 10:27 AM
BlackDeuceCoupe's Avatar
HT White Ops
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by G2_Fella &raquo;</TD></TR><TR><TD CLASS="quote">...can somebody give me the simple answer and tell me it's the "radiator?" i still doubt it's the radiator cus i see no leaking? what else could it be?</TD></TR></TABLE>
Never had a problem with my CiViCs, but...
I digress...
If you'll pardon the pun, I had a domestic with a 'hot' 390 small block V-8.
Ran great for years, but all of a sudden started overheating VIOLENTLY - sounded like Lucifer was beating the inside of my motor with hammers when I shut it off.
The cure was...
I took my 3-pass radiator to a racing radiator shop (they built custom rads for race cars). They pulled off the tanks and said the core was 75% blocked - and, BTW, I take great care of my cars! It was just old age and minerals doing their thing...
They stretched my tanks, installed a new 5-pass core, and guaranteed it to 500 HP.
Back on topic...
No amount of flushing will help a core that's plugged - and it doesn't take much!
Matter of fact, rodding it out won't even help, in this scenario - all they'll do is poke holes in the core, trying to rod it out.
Soooo, after you're tired of playing around with it, I'd bite the bullet and get a new radiator.
The two best ways I know of wrecking a motor is 1) run it with no oil and/or... 2) run it with no water/overheat it.
If you don't get a handle on it soon, you're gonna be s-o-r-r-y!
Modified by BlackDeuceCoupe at 11:34 AM 5/19/2008
Old May 19, 2008 | 10:45 AM
G2_Fella's Avatar
Default Re: (BlackDeuceCoupe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlackDeuceCoupe &raquo;</TD></TR><TR><TD CLASS="quote">
The cure was...
Modified by BlackDeuceCoupe at 11:34 AM 5/19/2008</TD></TR></TABLE>
thank you my man! thank you! this has got to be the next best step. some peeps mentioned head gasket, water pump, catalac converter? man, i'm laying those on the side! why not a dual core radiator! i'm going for it.
Old May 19, 2008 | 10:53 AM
G2_Fella's Avatar
Default Re: (h2392si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by h2392si &raquo;</TD></TR><TR><TD CLASS="quote">Try replacing the fan swith, radiator cap, new radiator, fan relay, water temp switch, waterpump, etc. you can replace many things you dont have to if you're not careful. You might have to take it to a mechanic to tell you what to do if you have that little knowledge. A new radiator for your car is 32$ shipped from ebay, FYI. </TD></TR></TABLE>the radiator cap was replaced brand new. next step would be the dual core radiator. all those other stuff i will lay it on the side for now.
having me looking at radiators on ebay is just like having me looking at bees on a bee hives.
Old May 20, 2008 | 06:43 PM
edfed's Avatar
You might look at the water pump- when the internal seals in mine went, my car was overheating left and right.
Old May 20, 2008 | 07:00 PM
G2_Fella's Avatar
Default Re: (edfed)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by edfed &raquo;</TD></TR><TR><TD CLASS="quote">You might look at the water pump- when the internal seals in mine went, my car was overheating left and right.</TD></TR></TABLE>did yours leak?
Null zahlen
19
Sep 14, 2009 02:10 PM
sgergg454
Mar 1, 2007 07:12 PM
hmtcrxsir
14
Aug 10, 2006 04:12 AM
dev
Jul 3, 2006 06:54 PM
streetracerof06
Dec 8, 2005 03:03 PM
