ecu light ????
Old May 19, 2008 | 05:08 AM
evo8psi23's Avatar
Default ecu light ????
so i have a b16a swap that the car came with and it idols a little wierd when its cold and the ecu has a red light in the middle of the ecu that has 2 long blinks than 2 fast blinks never saw a ecu with a red light before any ideas ????
Old May 19, 2008 | 07:03 AM
vitaminb18a1's Avatar
Default Re: ecu light ???? (evo8psi23)
The red light tells you what code the computer is throwing (Whats wrong with your car) its part of on board diagnostics. Two long blinks and two short blinks indicated code number 22 which is Variable Valve Timing & Valve Lift Electronic Control Pressure Switch (VTEC Pressure Switch).. Problems with your VTAK lulz
Old May 20, 2008 | 10:11 AM
evo8psi23's Avatar
Default Re: ecu light ???? (vitaminb18a1)
so where is the pressure silionid at ???? vtec still opens up though so would that be the problem still??? also on the ecu there is a white wire with a yellow stirp that is cut and jumped to a black wire on the opposite side of the ecu dunno why..... and how do i tell if its a us ecu or jdm thanks
efjones9
16
Jun 10, 2009 08:33 AM
jfields06
Dec 27, 2008 06:42 AM
d!ckface
Apr 22, 2007 04:22 PM
frostt3ch
10
Jun 22, 2003 11:09 AM
ZColeon
Oct 22, 2001 06:48 PM
