1991 Honda Accord EX-R Valve Cover Gasket
Old May 18, 2008 | 04:33 PM
JeffyHfx's Avatar
Default 1991 Honda Accord EX-R Valve Cover Gasket
Greetings all,
I purchased a 1991 Honda Accord EX-R a few months ago. I love it. I have just rolled 350000km or 217480 mi for you guys to the south of Canada Anyways I need to change my valve cover gasket. I bought the kit and there are lots of O-rings etc. I was wondering if anyone has done this before and if it is complicated?
Thanks
Jeff
Old May 18, 2008 | 06:21 PM
BLKFLSH's Avatar
Default Re: 1991 Honda Accord EX-R Valve Cover Gasket (JeffyHfx)
The large donuts go around the spark plug tubes under the valve cover. The o-rings go under the rocker arm assembly. I would not change the o-rings, unless you are getting oil into the spark plug tubes. There also may be some of the little rubber grommets that go under the cap nuts. Apply a little Hondabond (or rtv gasket sealant) in the corners where the valve cover goes over the camshaft. The little cap nuts are ONLY TO BE TORQUED AT 7LB FT. If you try to tighten them too much, it will easily snap the little studs off the head bolts.
Old May 18, 2008 | 07:39 PM
JeffyHfx's Avatar
Default Re: 1991 Honda Accord EX-R Valve Cover Gasket (BLKFLSH)
Thanks alot. Yes I am getting oil in on top of my spark plugs so I have to change everything. Thanks for the tips. I am glad I joined this forum.
Old May 18, 2008 | 10:39 PM
Losiracer2's Avatar
if you change the rocker arm o-rings, you'd have to do a valve adjustment soon after otherwise you'll run the risk of having the valves be way outta spec. It should be .10 for intake and .12 for exhaust valve clearances. I would also suggest buying a Haynes manual, it was pretty helpful for me.
94 accord typeR
Honda Civic (2006 - 2015)
10
Feb 6, 2018 07:47 PM
HGZ
Feb 18, 2007 11:27 AM
standbackimapro
Dec 16, 2005 11:07 AM
tlm756
Jul 18, 2004 02:13 PM
4genaccordfreak
Jan 4, 2004 01:07 PM
