Boomslang dpfi->mpfi obd0->obd1 conversion, no spark!
Old May 18, 2008 | 03:46 PM
Fuzzy Rhubarb's Avatar
Default Boomslang dpfi->mpfi obd0->obd1 conversion, no spark!
I just installed the dpfi odb0-obd1 conversion harness from boomslang. I quadrupled checked all my wiring and swapped the white wires. I'm really starting to think it's the dizzy. Are there any ways I can test it? It's a z6 dizzy
Old May 19, 2008 | 07:37 PM
Default Re: Boomslang dpfi->mpfi obd0->obd1 conversion, no spark! (Fuzzy Rhubarb)
I can't figure this damn thing out! I followed the instructions EXACTLY, my wires match up 1:1 except for the white one (which I flipped just to be sure.) I have a ground on the thermostat. I know the ecu works, and I'm not throwing any codes. I did find fuse 18 burnt out. I replaced it and still NO SPARK. Could there be anything else wrong, other than a bad dizzy?
Old May 19, 2008 | 08:02 PM
nfereorhatch's Avatar
i have the same harness and my swap went like clock work. when you say no spark what exactly do you mean, what is the car doing?
Old May 19, 2008 | 08:09 PM
Default Re: Boomslang dpfi->mpfi obd0->obd1 conversion, no spark! (nfereorhatch)
just cranking, no spark as in no spark directly off the coil, the ecu powers up fine, tried it in a friends car. no codes, I can even unplug sensors and have them cause an cel. I just can't figure out why I have no spark.
Old May 19, 2008 | 09:20 PM
D16SiHatch's Avatar
is this a known good dizzy? check for power at the distributor. believe its like a black/yellow wire comin out the side, right next to the blue tach lead wire.
Old May 20, 2008 | 05:25 AM
Default Re: Boomslang dpfi->mpfi obd0->obd1 conversion, no spark! (D16SiHatch)
i have 12.2 at the ignition wire. are there any other checks i can do to make sure the wiring is correct?
StreetsideStig
Sep 28, 2012 05:48 AM
ryanevansoh
11
Mar 24, 2012 07:40 PM
whiterex
Feb 24, 2005 09:02 AM
95turbohatch
24
Apr 7, 2004 08:07 PM
KevronsEG
11
Mar 28, 2003 05:42 AM
