I dont think my Vtec pops...
I have a 97 coupe ex model.
d16y7 in it.
When is vtec supposed to engage? 5200?
Well i hear nor feel a difference in power when in that range of rpm.
I've been in a single cam vtec and i actually heard a difference....Not too much of a power difference though...I'm going to build my single cam soon so i just wanted to know why the vtec wouldn't be popping...
I have oil so its not low oil..
d16y7 in it.
First of all there are like 4 or 5 things that have to happen for vtec to kick in and that is 1.operating temp (closed loop) 2. set rpm (which should be around 5-5.5k 3. its like 52 or 57psi of oil pressure ( so just having oil dosent make it work) 4. vss has to be showing at least 11mph. I think that is it but a little more on the oil pressure thing, my homie's vtec was coming on and off and it took forever for him to realize that there was a small dent in oil pan not allowing the pickup to get enough oil to build the right amount of pressure so as you can see there can be a little more then just having oil and that list dosent even cover stuff like wiring, solenoids, switchs, etc. etc. but maybe that might help you. good luck
allmotorsi04
Mar 23, 2006 07:13 PM
