FS: Acura NSX front and rear brake calipers Zanardi edition / 97-05
FS: NSX caliper set - SOLD!
For sale is a complete set of the NSX calipers with brackets. The fronts are from a 98 NSX which has the bigger 11.8" brakes (as do the pre 97 models that are the Zanardi edition.)
The rears are from a 98 also with the bigger 11.8" brakes and elongated heat vanes. These are in great shape, none of the seals have any damage and were taken off a working car, and they are painted blue with white letters. The paint is not an epoxy shell but is very durable, so they will hold up but also can be stripped with paint remover. They come with all hardware and OEM pads with the OEM shims. The pads I believe are a semi-metallic compound up front and the OEM compound in the back.
These are a direct bolt-on for 91-97 NSXs to use the 97-05 rotors.
These can be fitted to Civics and Integras in the front with a little spacing and in the back with the fastbrakes adapter.
Modified by BrakeExpert at 2:06 PM 8/4/2008
I said they should be up in a few days when I get home where my camera is. The only picture is in my avatar when they were mounted.
What's this about pre-97 Zanardi? Zanardi was just 99, wasn't it? Unless your'e talking about JDM Type-S?
The early NSXs, like before 97 had smaller 11.1" brakes. These are for the 11.8". These were found on the Zanardi Edition, Type-S, Type-R, and all the later models (the NSX only had two different brake setups.)
Hey brake expert is the nsx front caliper a 2 piston caliper. Also how much of a difference is there between the weight of the nsx caliper and the s2000 caliper?
scorp965
Mar 24, 2010 11:05 PM
chameleon
Dec 3, 2003 01:24 AM
