FOR ALL OBDII JDM ENGINE USERS, did your motor include,,,,
Old May 18, 2008 | 11:56 AM
DOHC Kid's Avatar
Default FOR ALL OBDII JDM ENGINE USERS, did your motor include,,,,
a knock sensor or knock sensor port? Needed for inspection.
Old May 18, 2008 | 12:00 PM
RyanA's Avatar
Default Re: FOR ALL OBDII JDM ENGINE USERS, did your motor include,,,, (DOHC Kid)
Well, do you have an OBDII engine that requires a knock sensor?? Typically, an engine that requires a KS has a KS. Did you take a VTEC engine out of your car and put a non-VTEC one in? And how the heck did these people figure out you need a KS? IF you are running a JDM ECU, they can't even communicate with it via the OBD2 port which is why I'm curious.
Bottom line: JDM VTEC engine has knock sensor
Some JDM non VTEC engines don't have KS's and some do. If you have to add one, you can retap a hole for the alternator upper bracket and screw it in there.
redlines4us
Jun 29, 2009 04:26 AM
RyanA
Jul 4, 2007 04:58 AM
JDMF22B
Jun 22, 2005 03:49 PM
USDMMARK
Feb 12, 2004 08:21 AM
voltageGSR
Jan 5, 2004 10:01 AM
