tranny filler bolt
take off your passenger side wheel its on the side of the tranny above the socket bolt/drain bolt.
I think the filler bolt is like a 17mm but im not sure.
Edit: Here is what I used to replace my tranny fluid
http://www.team-integra.net/se...D=301
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tegra2G »</TD></TR><TR><TD CLASS="quote">its not a 17mm blot its just a 3/8 drive end of a ratchet</TD></TR></TABLE>
the 3/8 rachet is used for the drain bolt but a 17mm is needed to remove the filler bolt on the side of the tranny.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wangg125 »</TD></TR><TR><TD CLASS="quote">
the 3/8 rachet is used for the drain bolt but a 17mm is needed to remove the filler bolt on the side of the tranny.</TD></TR></TABLE>
x2
x2
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18c1ej8 »</TD></TR><TR><TD CLASS="quote">doing it through the speed sensor on top of the tranny is the easiest to put fluid back in</TD></TR></TABLE>
You will still have to pull the filler bolt to use it as a fill line, otherwise you're going at it blind.
doom26464
Jun 18, 2008 07:10 PM
miksew
12
Aug 13, 2006 09:41 AM
Drian
Mar 17, 2004 03:28 PM
asubennett
Aug 21, 2003 05:14 PM
