What paint do you guys use to spray your trim?
Old May 18, 2008 | 10:51 AM
hondacivic90zc's Avatar
Default What paint do you guys use to spray your trim?
Like the topic says. What brands and types of spray paint do you guys recommend?
Old May 18, 2008 | 11:11 AM
ReactioN's Avatar
* B A N N E D *
Default Re: What paint do you guys use to spray your trim? (hondacivic90zc)
Kylon Fusion for plastics??
Old May 18, 2008 | 02:36 PM
JDM808's Avatar
Dupont has paint for trim, but you might have to invest on a paint gun.
Old May 18, 2008 | 04:48 PM
boost'd_crx's Avatar
Default Re: (JDM808)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM808 &raquo;</TD></TR><TR><TD CLASS="quote">Dupont has paint for trim, but you might have to invest on a paint gun. </TD></TR></TABLE>
they also have one in the spray can form. works well
Old May 18, 2008 | 07:17 PM
DDEVIANT1's Avatar
Default Re: (boost'd_crx)
Pro form makes a killer trim paint. European trim and bumper black...
Old May 18, 2008 | 07:29 PM
slacks's Avatar
Default Re: (DDEVIANT1)
my friend used SEM trim paint for his interior and it looks really nice and holds up too
Old May 18, 2008 | 07:31 PM
Default Re: (slacks)
thanks for the responses
Old May 20, 2008 | 04:59 PM
swappedcx's Avatar
Default Re: (hondacivic90zc)
scuff-&gt; adhesion promoter on some plastics, if metal skip that-&gt; epoxy primer-&gt; base-&gt; clear-&gt; done.
Old May 21, 2008 | 04:56 PM
JDM808's Avatar
Default Re: (swappedcx)
yup, need to prep it good for it to hold up well.
Old May 21, 2008 | 05:36 PM
Mr.CrackHead's Avatar
I use dupli-color from kragen
Old May 21, 2008 | 05:59 PM
Genuine Rolla's Avatar
There is actually paint out there called "trim paint".
Comes out pretty nice.
Old May 24, 2008 | 12:06 AM
iam7head's Avatar
Default Re: (Genuine Rolla)
what paint depends on what finish you want, if you want a shiny oem colorpaint then you have go to spray gun route, if you just want a matte/semi matte black then just use a rattle bomb
sem make a sick **** interior rattle bomb 10buck a pop
Old May 24, 2008 | 01:04 PM
Default Re: (iam7head)
yeah im just looking for a matte black to rejuvinate my fading trim and bumpers.
Old May 25, 2008 | 10:59 AM
matryx's Avatar
Here's what I did using Kylon Fusion for plastics. All I did was wash all the dirt off and let it dry before I sprayed it on. I like the results. My trim was all scratched up and faded before. I did probably around 2-3 thin coats. I'm still letting it dry for now. I'm not sure if I need to clear it or anything. Hopefully it won't flaked off
Old May 25, 2008 | 08:03 PM
kiddcarbuff's Avatar
scuff with red pad. then dupont plaStick. and then ill add some flex to my primer/base and clear
Old May 26, 2008 | 02:30 AM
Stunna MIKE's Avatar
Default Re: (matryx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by matryx &raquo;</TD></TR><TR><TD CLASS="quote">Here's what I did using Kylon Fusion for plastics. All I did was wash all the dirt off and let it dry before I sprayed it on. I like the results. My trim was all scratched up and faded before. I did probably around 2-3 thin coats. I'm still letting it dry for now. I'm not sure if I need to clear it or anything. Hopefully it won't flaked off
That doesn't look to good. Its too shiny, and in some spots more than others.
Old May 29, 2008 | 01:11 PM
matryx's Avatar
do you guys think I need to clear these after using Krylon paint for plastic? I went over it with my finger tips yesterday and I get some of it on my finger. What can I do?
Old May 30, 2008 | 09:10 AM
c_rogue69's Avatar
I work at a body shop and this is what we use
Old May 30, 2008 | 01:48 PM
pat92si's Avatar
Default Re: (c_rogue69)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by c_rogue69 &raquo;</TD></TR><TR><TD CLASS="quote">I work at a body shop and this is what we use
same here man, looks great
Old May 30, 2008 | 02:01 PM
matryx's Avatar
says it's for exterior trim though. Does it work well with interior trim?
Old May 30, 2008 | 10:52 PM
c_rogue69's Avatar
yeah, works with exterior trim
Old May 31, 2008 | 01:44 PM
sh!tsWEAK!'s Avatar
Yes, use SEM Trim Black. They even have a specific color called "Honda Trim Black". Forget duplicolor, krylon, and all those....SEM is top notch stuff.
Old May 31, 2008 | 03:06 PM
jdm_dc_fan's Avatar
From: "That one guy with that one car" Kennewick WA
where can you buy that sem stuff? all i see at local auto stores is krylon and other cheap paint. ive had bad experience with krylon
Old May 31, 2008 | 04:01 PM
sh!tsWEAK!'s Avatar
Default Re: (jdm_dc_fan)
You need to go to a place that sells automotive paint - NOT autozone/advance. Check SEM's website to locate a dealer near you.
Old Jun 3, 2008 | 06:17 PM
datniguhphu's Avatar
Default Re: (sh!tsWEAK!)
you should go try plastics dip is the best thing out there, go look up on it...
Multi-purpose air dry, synthetic rubber coating that can be easily applied by spraying, brushing or dipping. Plasti Dip resists moisture, acids, abrasion, corrosion, skidding/slipping, and provides a comfortable, controlled grip. It remains flexible, stretchy and will not become brittle or crack in extreme weather conditions
FishyMan
Paint and Body
Feb 28, 2009 06:17 PM
rewerbcrx
Paint and Body
Feb 23, 2008 12:11 PM
jaydem7
Paint and Body
Sep 11, 2007 10:52 AM
JUN.
Apr 5, 2006 02:44 PM
deeweezy
Aug 17, 2003 07:19 AM
