MORE OIL LEAKS!! Engine code and high idle??
it's a 95 ex, w/ a jdm b16a. I recently had the rear, and front main seals replaced. also the oil pan gasket...Everything has been fine for the last few weeks. I turned the boost up from about 6psi, to 9psi. I raced a 240sx last night, and had no problems. Brought it home...and parked it for the night. This morning...I left for work, and it was running fine, until I was in 5th gear cruising along, I just spooled up my turbo, and I threw a check engine light about 5-10 seconds after spooling up! So I let off, and just cruised and watched my guages. My water temp started to go up, so I pulled over, and popped the hood. For some reason...it was idling at like 1500rpm, instead of like 800...idk why?? Then...when I popped the hood, it was buring a lot of oil. Smoking. I can see nowhere in the engine bay where it is leaking, or even wet! Under the car...It is definitly leaking, and it looks like around the rear main seal AGAIN!!!
But that wouldn't explain the high idle, or the code either. So idk. Any thoughts? Any info needed just ask... Thx.
bluemc
Mar 10, 2012 08:44 AM
