power steering again
Old May 18, 2008 | 09:05 AM
thepel's Avatar
Default power steering again
Ok, so i've already replaced my power steering pump once, and the rack about 6 months ago. now, I get my car back from my old shop yesterday and last night the power steering pump started to make a low whining noise thats only noticeable at idle. i read from another post that if you don't use honda ps fluid that it will mess up the pump and seals, is this true? and then should i just flush the ps fluid, or do i need to get another pump?
Old May 18, 2008 | 12:07 PM
Hawkze_2.3's Avatar
Default Re: power steering again (thepel)
Yea, non-Honda fluid could probably make it go bad over time...I would drain and refill with Honda stuff and see if it gets any better. Also check you belt tension...could be too tight.
Old May 19, 2008 | 03:31 PM
thepel's Avatar
ok so the non-Honda ps fluid is a mixed bag of answers from 2 race shop mechanics and 2 dealerships i talked to. but it turns out that it was my harmonic balancer that was going fast...cause today any revs over 6k wash shaking the whole car. thanks though.
Old May 19, 2008 | 09:05 PM
Hawkze_2.3's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thepel &raquo;</TD></TR><TR><TD CLASS="quote"> but it turns out that it was my harmonic balancer that was going fast...cause today any revs over 6k wash shaking the whole car. thanks though. </TD></TR></TABLE>
Uhh...what happened to it? The rubber ring separated or the bolt came loose?
Old May 19, 2008 | 11:55 PM
thepel's Avatar
Default Re: power steering again (Hawkze_2.3)
the rubber ring separated...like maybe 25 miles before it would have completely f'd my engine...thankfully i caught it in time.
Old May 20, 2008 | 08:44 AM
Hawkze_2.3's Avatar
Yikes!
Old May 20, 2008 | 02:39 PM
Fongman's Avatar
did you buy new or rebuilt units? some rebuilt are not good?
FMohlmann
Nov 18, 2016 12:28 PM
Silvteg95
Aug 1, 2005 06:59 PM
'00Accordster
Sep 25, 2004 08:52 AM
-[95cxhatch]-
Apr 12, 2004 01:38 PM
