WHat happens when you try and check a CEL code, and your CEL is not on?
I have a 92 civic DX, 90k miles. I would say once every 2 months the CEL light comes on...I immediately turn the car off and turn it back on and it doesnt come on for like another 2 months.(and I drive it a good amount)
WHat would happen if I tried to check the code with the 2 pin connector tutorial? I guess what im trying to say is what happens if your car is not throwing a code, but you check for one? WIll the CEL still flash, or just do nothing?
I check OBDII cars often and I've scanned cars that were supposed to have recently had check engine lights on, but it's now off. Sometimes something shows but it usually doesn't. I believe the CEL still usually lights if you have a stored code.
This could be different for OBDI cars though.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote »</TD></TR><TR><TD CLASS="quote"> want to buy something in the classifieds but I am on trial!!! Someone unlock my account. Thank you.
Kris</TD></TR></TABLE>
"Permission Level Unrestricted User"
You are not on trial. Moderators also do not unlock accounts. It should automatically change after you've goen through the trial membership period.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by krisfnbs »</TD></TR><TR><TD CLASS="quote">WHat would happen if I tried to check the code with the 2 pin connector tutorial? I guess what im trying to say is what happens if your car is not throwing a code, but you check for one? WIll the CEL still flash, or just do nothing?</TD></TR></TABLE>
When connector is jumped:
No Codes Present/Stored = Solid CEL
Code(s) Present/Stored = Flashing Pattern
Next time the CEL pops up while driving, don't turn the car off. Just pull over and jumper the connector to read the code.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by obuhmyuh »</TD></TR><TR><TD CLASS="quote">not tryin to thread jack, but is it bad to leave it jumped?</TD></TR></TABLE>
I would imagine it's not best to do so. The jumper is also intended to prevent the ECU from changing timing while you adjust it manually via the distributor's rotation. What I do is install a switch (glovebox or elsewhere) to flip as needed to check codes or adjust timing.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueCrxNC »</TD></TR><TR><TD CLASS="quote">
I would imagine it's not best to do so. The jumper is also intended to prevent the ECU from changing timing while you adjust it manually via the distributor's rotation. What I do is install a switch (glovebox or elsewhere) to flip as needed to check codes or adjust timing.</TD></TR></TABLE>
thanks, im just waiting to get a new ECU to clear my codes, and ill remove it, but I don't mess with timing... for now... Once again, thanks and sorry for jacking.
yea mine comes on every once and while also and turn it off then back on with no cel. I still check it and it steady comes back 1 and 43 so i figure 43 is making 1 come on in my obd1
