Type R Engine Rebuild (GoFightKill) Lots of Pics
Old May 18, 2008 | 06:09 AM
REDLINEtypeR's Avatar
Default Type R Engine Rebuild (GoFightKill) Lots of Pics
This R like many other is worn out from a hard life and now it eats way too much oil. This is the 3rd on i have rebuilt in the car like this with excellent results. The only upgrades we did were ARP headstuds and supertec valvesprings. Everything else is done with OEM parts the way it should be. Enjoy!!
Dirty burnt oil stained head
#1 cylinder was the worst, notice the buildup on the valves
#1 cylinder was washed down due to blowby and excess unburned fuel
How 113k cylinder walls look
Torn apart R
Let the honing begin
fresh crosshatch
Fresh head all clean with valvejob and a fresh mill. so pretty
ARP studs and a new oem headgasket
torque the head correctly
DONE
He is breaking it in now. Another R motor saved. Thx for looking.
Old May 18, 2008 | 06:37 AM
teg97's Avatar
Default Re: Type R Engine Rebuild (GoFightKill) Lots of Pics (REDLINEtypeR)
nice job
Old May 18, 2008 | 07:12 AM
itrSteez's Avatar
Hell yeah, about damn time jordan
You better hope your boss doesn't see you getting your work done somewhere else
Old May 18, 2008 | 08:31 AM
GO-FIGHT-KILL's Avatar
Haha, they're well aware where my car was all week.
Glad to finally have it done. No more burnt oil smell at stop lights.
Old May 18, 2008 | 09:04 AM
Doespike's Avatar
Default Re: (GO-FIGHT-KILL)
Congrats on the rebuild mang, glad it went well
<--in for dyno vid
Old May 18, 2008 | 09:12 AM
^ Dialing her back in with the AEM on Monday or Tuesday.
Old May 18, 2008 | 09:16 AM
len's Avatar
len
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GO-FIGHT-KILL &raquo;</TD></TR><TR><TD CLASS="quote">^ Dialing her back in with the AEM on Monday or Tuesday. </TD></TR></TABLE>
Was the hone strictly for cleaning and cutting in new cross-hatching so the rings could seat better?
Old May 18, 2008 | 09:38 AM
jvtec95's Avatar
Default Re: (len)
Where did you get the hone? I'm about to do the same thing myself, curious on specs on it. My cylinder walls are like mirrors .
Old May 18, 2008 | 10:31 AM
vicsir's Avatar
been wanting that done on my R. so all that done is new head gasket, cyclinfer walls honned. Are the piston rings replaced, and i guess new timing belt water pump would be benifcial? as for the head all the valvetrain is new right? what exactly gets milled ?
thanks, like the write up
Old May 18, 2008 | 11:24 AM
buda18's Avatar
Default Re: Type R Engine Rebuild (vicsir)
im not familiar with the details of honing a block, but it looks like the crank was still in the block when honing. doesn't this lead to shaving falling down onto the crank and any other hole or crevice it can find its way into?
so, take off the head, take out the rods and pistons, hone, install rods and pistons, then head?
how do you remove the rods and pistons from the top, or did you?
Old May 18, 2008 | 01:24 PM
beaterman's Avatar
Default Re: Type R Engine Rebuild (buda18)
damn that thing looks nice Jordan. Saw it up at the shop the other day when I was gettin my car done. to Redline SpeedShop. Red does great work at a very fair price.
Old May 18, 2008 | 01:59 PM
Default Re: Type R Engine Rebuild (beaterman)
It all went well. The hone is just available at any auto parts store for your bore. As for it getting on the crank, not a problem. The journals are all covered and cleaned thoroughly before install. The honing is to allow the rings to have a fresh surface to seat together. There are a lot of parts replaced. The valvejob and mill are necessary to have fresh surfaces so the engine feels like new. Any seals, gaskets, or o-rings you encounter along the way should be replaced. Thx for the compliments. Glad to help another R.
Old May 18, 2008 | 02:50 PM
Aquafina's Avatar
left the crank in when you honed?
Old May 18, 2008 | 03:03 PM
The first three oil changes showed no shavings of any kind, the magnet showed no shavings of any kind. Apparently it worked.
Put 200 miles on it last night and this morning. Just got it off the dyno, we had it on there for a few hours load testing it in high RPM... ZERO smoke, the motor's running incredibly healthy. Did a new mild tune on the AEM, the car's running much better with the tune.
Going to give it another 500 miles, and retune it a little more aggressive. Should be about a week before EXPO.
Old May 18, 2008 | 03:09 PM
get RIGHT's Avatar
Great job.
Old May 18, 2008 | 03:51 PM
Kenso's Avatar
HT White Ops
Default Re: (Aquafina)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Aquafina &raquo;</TD></TR><TR><TD CLASS="quote">left the crank in when you honed? </TD></TR></TABLE>
If you're doing an in-car overhaul, that's your most realistic option. Pulling the crank with the block in the car would be retarded, at that point you might as well pull the whole motor and do it on a stand ($$).
Nice to have a clean rear bumper for a change I'll bet. Have fun with it at Expo Jordan.
Old May 18, 2008 | 04:16 PM
^ Thanks Ken.
Old May 18, 2008 | 04:54 PM
Doostur's Avatar
Looks like fun
Poor thing had a hard life.
Old May 18, 2008 | 05:08 PM
^ It's not going to get any easier either.
Old May 18, 2008 | 07:15 PM
fuko's Avatar
awesome job on the rebuild, but learn to use the "macro" button on the camera next time, you know, the one with the little flower icon
Old May 18, 2008 | 09:17 PM
DOMKID's Avatar
Default Re: (fuko)
nice job. How much do you charge to do something like this? also, did you port the head or was it just a valve job?
Old May 19, 2008 | 04:54 AM
robfrmny21's Avatar
Default Re: (DOMKID)
what was the down time for this??
Old May 19, 2008 | 05:56 AM
^ Dropped it off Monday night, picked it up Saturday afternoon.
Can't beat that.
CW-ITR's Avatar
Default Re: (robfrmny21)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by robfrmny21 &raquo;</TD></TR><TR><TD CLASS="quote">what was the down time for this??</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GO-FIGHT-KILL &raquo;</TD></TR><TR><TD CLASS="quote">Haha, they're well aware where my car was all week. Glad to finally have it done. No more burnt oil smell at stop lights.</TD></TR></TABLE>
Old May 19, 2008 | 04:06 PM
Thx for the props guys. Glad you liked the pics. They can be fixed at an affordable price as long as you just do what is neccesary. They are hondas so they run a long time anyways. this is just regular maintainance for R's.
