sounds like wheel beering went out?
Old May 18, 2008 | 04:02 AM
vdawg559's Avatar
Default sounds like wheel beering went out?
when slowly letting go the clutch an pressing on the gas. you can head like metal grinding an it would stop as i keep goin... any ideas? this just recently had happen to me
Old May 18, 2008 | 07:27 AM
shortlid's Avatar
Default Re: sounds like wheel beering went out? (vdawg559)
Does it still make the sound when in nutreal and rolling? Sounds like a clutch issue to me?
Old May 19, 2008 | 01:30 AM
vdawg559's Avatar
when i go punch my car. you can hear the metal like rubbing an stuff
Old May 19, 2008 | 02:43 AM
EGB18CT's Avatar
does it squeek when u turn? go over bumps? squeek at lower speeds and and get less loud the faster you go? if not then it may be an isb or thrust bearing in your gearbox??
Old May 20, 2008 | 02:01 AM
vdawg559's Avatar
doesnt squeak when i turn nor does over the bumps. but when i jack up the car, an wiggle the driver side wheel it moves. like on a bicycle
Old May 20, 2008 | 10:24 AM
Str8EJ's Avatar
it's been my experience that a bad wheel bearing sounds like a cyclical hum...sort of wobbly. it gets worse at higher speeds (unlike an improper alignment).
try to isolate what causes the noise. ie: is it from releasing the clutch or applying throttle (?)
Old May 21, 2008 | 01:15 AM
vdawg559's Avatar
just when throttling. y0u can hear it alil in 2nd gear if im goin fast/ an i just replace the bearing. so the grinding noise went away. but now it seems like something is rubbing. any one had dis experience before?" an here something. my driverside rotors isnt bolt on. can that b the thing making the noise?
Old May 21, 2008 | 02:52 AM
vogueVTI's Avatar
Default Re: (vdawg559)
Sounds like a clutch release bearing problem to me.
Get someone to press the clutch up and down whilst you listen under the hood around the gearbox area. Listen for a high pitched noise, squeeking or grinding etc.
Good luck
Old May 22, 2008 | 02:00 AM
vdawg559's Avatar
more info on the noise. sounds like reversing but in first gear/ an some slightly noise on 2nd. but still the car still fast aha. can it b some braking isssue? like worn out parts an rotots?
an ima try
vdawg559's Avatar
out that clutch releasing
Old May 22, 2008 | 01:46 PM
vdawg559's Avatar
up
Old May 22, 2008 | 02:17 PM
bigsyke's Avatar
you guys kidding me? Either your caliper piston is frozen, or your brakes arent releasing, which means you need new caliper pins which you can sand down and relube. And then bleed your breaks.
Your wheel bearing only makes noise at a certain speed/apex. As he continues to accellerate, the noise will continue for about 10 seconds and stop? yea thats the brakes loosening tension. Relube, and check the brake pad clips warpage, I usually just grind the clips down a bit to allow the pads to slide back adn forth easier
Old May 23, 2008 | 02:32 AM
vdawg559's Avatar
lift up the car an put it in gear an let it ran. no noise was made. one of my buddy says it can b throw out bearing.
Old May 23, 2008 | 02:34 AM
vdawg559's Avatar
Default Re: (bigsyke)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bigsyke &raquo;</TD></TR><TR><TD CLASS="quote">you guys kidding me? Either your caliper piston is frozen, or your brakes arent releasing, which means you need new caliper pins which you can sand down and relube. And then bleed your breaks.
Your wheel bearing only makes noise at a certain speed/apex. As he continues to accellerate, the noise will continue for about 10 seconds and stop? yea thats the brakes loosening tension. Relube, and check the brake pad clips warpage, I usually just grind the clips down a bit to allow the pads to slide back adn forth easier</TD></TR></TABLE>
yeah. as i accelerate it would get louder but when i stop an shift gear it would go away. some. an where can i check the brake loosening tension?&gt; some tips please
Old May 24, 2008 | 02:05 AM
vdawg559's Avatar
up
Old May 24, 2008 | 08:16 AM
bigsyke's Avatar
do a full brake job and see if it fixes it.
Ej2guy28
Mar 26, 2013 01:18 PM
michael123
10
Feb 19, 2008 10:32 AM
kamil_cnd
Apr 7, 2006 09:47 AM
drewbie
May 9, 2004 12:31 PM
