type s head swap
Old May 17, 2008 | 09:33 PM
2000h22a's Avatar
Default type s head swap
what would i stand to gain from switching my stock base model 2000 prelude h22 head with the head of a type s motor? any significant difference? i assume it is not that difficult and there is little or no fabrication invloved because they are after all the same motor
any advice is appreciated
Old May 17, 2008 | 10:09 PM
boostdlude's Avatar
Default Re: type s head swap (2000h22a)
to be completely honest... i wouldnt swap in a type s motor. sure its has close to 20+ hp over a usdm h22 but for the price of it your better just getting a jdm h22a its still more horse power the usdm and not as expensive. if you really wanna go w/ something that is better go we a euro r . 230 hp and if you get the tranny w/ it ...it has the shortest h22 gears. IMO hope this helps.
Old May 17, 2008 | 10:36 PM
218luder's Avatar
Default Re: type s head swap (boostdlude)
he isnt talkin about a full type s swap, he's just talkin about the head itself. but to the OP i believe there isnt much of a difference. if you really wanted to see some gains i would suggest to swap over the type s pistons.
Old May 19, 2008 | 06:34 PM
2000h22a's Avatar
Default Re: type s head swap (218luder)
those are 11:1 comp right?
Old May 20, 2008 | 01:02 PM
218luder's Avatar
yep 11:1 compression ratio
skata89
Mar 13, 2006 05:59 PM
WeekH22#2
Nov 8, 2005 07:13 PM
02NJHondaep3
Feb 22, 2004 10:52 AM
