memoryfab intake questions
Old May 17, 2008 | 08:07 PM
Thorgs's Avatar
Default memoryfab intake questions
I have 2 question regarding a memoryfab intake I just picked up.
1. What are you guys using to fill in this extra hole in the intake?
2. What are you replacing the coolant line with (the lower one on the metal feeder)?
Old May 17, 2008 | 08:31 PM
94 IntegraLS's Avatar
Default Re: memoryfab intake questions (Thorgs)
When I installed my AEM SRI I just went to home depot and got a coupling type fitting and connected the two coolant lines together and removed that metal piece completely.
Old May 17, 2008 | 08:40 PM
Default Re: memoryfab intake questions (94 IntegraLS)
Basically its the 1st fitting on this page http://www.plumbingsupply.com/barb.html and I think the size you need is 3/8"
Old May 17, 2008 | 10:21 PM
Thorgs's Avatar
cool thanks man. i was at home dept the other day but couldn't find those in the store. i guess i'll hit them up again.
Old May 18, 2008 | 12:11 PM
It should be near those Ice maker kits for refridgerators... or atleast at the home depot I go to it is.
Old May 18, 2008 | 02:02 PM
TastyDragon's Avatar
for tha first one you could also use a 3/8" i forgot what theyre called but theyre basically rubber foot things for tables and what not. and it'll go over tha little tube. you can get it at home depot theyre tan and come in a pack of 4
o and for tha second one, when you open tha coolant lines nothing will anything come out? and you post a picture of tha cupling you used?
Old May 18, 2008 | 04:55 PM
Thorgs's Avatar
Default Re: memoryfab intake questions (TastyDragon)
Thanks, I found the coupling at Home Dept in the plumbing section (they were hidden behind a ladder). I just used the clamps that clamped the hoses to the metal feeder (which was deleted) to clamp the hoses do the coupling. I don't have a pic but it's the same as the one that was given in the link above. I guess I'll just stick with my electrical tape for now for the hole on the back since I threw the tube out. I just wish I could find a rubber grommet for it. Oh well. Thanks again for all the help guys
Here's what it looks like.
It's a pain to install but once it's in it's nice and tight.
Old May 18, 2008 | 08:40 PM
will coolant spill out when you disconnect it to put in tha coupling?
Old May 19, 2008 | 11:14 AM
Very little will spill out unless you turn the tubes upside down and let them drain. but when I did mine only a couple drops of coolant came out.
Old May 20, 2008 | 08:12 PM
Thorgs's Avatar
I took the "S" hose off to make it easier to install the coupling so coolant came out. Not a lot, just what was in the hoses. I turned the car on after installing (with clamps on the coupling) and could hear the coolant rushing back into the hose. My idle was bouncy for a little bit, but once the coolant loop is back to normal you should be good to go.
vtecnique69
Honda Civic (2006 - 2015)
Sep 21, 2014 08:15 AM
giantgreenhead
Dec 9, 2007 02:24 PM
Marksri
Feb 4, 2006 06:39 AM
Rick
Aug 26, 2003 10:54 PM
Starrman85
Dec 17, 2002 08:45 PM
