Cheap, DIY Way of making your own Balancer shaft removal kit for H/F Motors
Old May 17, 2008 | 04:49 PM
Turbo EH2's Avatar
* B A N N E D *
Default Cheap, DIY Way of making your own Balancer shaft removal kit for H/F Motors
Just thought of it right now.. What if i just cut the balancer shaft right at where it bolts to the block? I would leave enough to where the bearing surface will seat properly and seal the hole but the rest of the balancer shaft will be cut off and removed completely. Let me know what you guys think. I am going to try this right now.. My main concern is how thick the balancer shaft is lol
Old May 17, 2008 | 04:57 PM
Agnom's Avatar
Default Re: Cheap, DIY Way of making your own Balancer shaft removal kit for H/F Motors (Turbo EH2)
If you not gonna remove the shaft, just leave the balance shaft belt out...
Old May 20, 2008 | 01:59 PM
FIST321's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Turbo EH2 &raquo;</TD></TR><TR><TD CLASS="quote">Just thought of it right now.. What if i just cut the balancer shaft right at where it bolts to the block? I would leave enough to where the bearing surface will seat properly and seal the hole but the rest of the balancer shaft will be cut off and removed completely. Let me know what you guys think. I am going to try this right now.. My main concern is how thick the balancer shaft is lol</TD></TR></TABLE>
this is how i did my half *** balancer removal good luck ur oil light gonna come on if the car doesnt idle above 1000 rpm if u dont block the oil passage ur gonna carrie about 5 psi of oil pressure till about 2000 rpms just buy the kazzin speed kit to do it right
Old May 20, 2008 | 02:53 PM
2fastGSR's Avatar
King of the One Liners
Default Re: Cheap, DIY Way of making your own Balancer shaft removal kit for H/F Motors (FIST321)
if you are going to be cheap then why not just tap the balance shaft hole and thread a block off in it
the point of removing the balance shaft is to lose weight. The way you are describing to do it would be just as affective saving all that time and just cutting the belt off and calling it a day
Rhymenoceros
Nov 22, 2007 12:16 PM
c-techracing
Jul 7, 2007 10:56 AM
CTL
Mar 8, 2004 07:11 AM
c jackson
Dec 20, 2003 08:46 PM
