New Service bulletin 08-032 Engine makes a clicking or tapping noise
During engine assembly, an incorrect exhaust rocker
arm shaft may have been installed. The incorrect shaft
does not allow proper lubrication to the camshaft
journals, which results in excessive heat buildup. In
some cases, the camshaft holder bolts loosen, allowing
the rocker arm shaft to move and causing a clicking or
a tapping noise.
Twenty-four (24) customer owned 2008 Civic Si’s may have the wrong exhaust rocker arm shaft installed in the cylinder head and need to be repaired. Six (6) additional vehicles have already been repaired.
VEHICLES AFFECTED
2008 Civic Si:
2HGFG21568H700044
2HGFG21588H700045
2HGFG215X8H700046
2HGFG21518H700047
2HGFG21538H700048
2HGFG21558H700049
2HGFG21538H700051
2HGFG21558H700052
2HGFG21578H700053
2HGFG21528H700056
2HGFG21568H700058
2HGFG21588H700059
2HGFG21548H700060
2HGFG21568H700061
2HGFG21588H700062
2HGFG215X8H700063
2HGFG21518H700064
2HGFG21558H700066
2HGFG21578H700067
2HGFG21598H700068
2HGFG21508H700069
2HGFG21578H700070
2HGFG21508H700072
2HGFG21528H700073
CORRECTIVE ACTION
Replace the cylinder head assembly.
NOTE: The loss of lubrication is only in the camshaft
and rocker arm area. There is no need to replace the
short block assembly.
a tapping noise.
VEHICLES AFFECTED
2008 Civic Si:
2HGFG21568H700044
2HGFG21588H700045
2HGFG215X8H700046
2HGFG21518H700047
2HGFG21538H700048
2HGFG21558H700049
2HGFG21538H700051
2HGFG21558H700052
2HGFG21578H700053
2HGFG21528H700056
2HGFG21568H700058
2HGFG21588H700059
2HGFG21548H700060
2HGFG21568H700061
2HGFG21588H700062
2HGFG215X8H700063
2HGFG21518H700064
2HGFG21558H700066
2HGFG21578H700067
2HGFG21598H700068
2HGFG21508H700069
2HGFG21578H700070
2HGFG21508H700072
2HGFG21528H700073
CORRECTIVE ACTION
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by djarch »</TD></TR><TR><TD CLASS="quote">Am I correct in assuming that only the 2008 si is affected?
hooray for having a 07, I guess.</TD></TR></TABLE>
Im pretty sure your right but my car and every other si i've driven makes a light tapping sound at idle.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kroze »</TD></TR><TR><TD CLASS="quote">this is what happen when you hire john "american" smith in Ohio to build your car rather than some asian guy in Japan.</TD></TR></TABLE>
Well most if not all of the 08 Si Motors are built in Japan.
Modified by 06BlackSi #45 at 12:53 PM 5/20/2008
phew! I am glad my 08 mugen si is not in that list....can u post a copy of that tsb? to ensure others
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tokyosmash! »</TD></TR><TR><TD CLASS="quote">
Im pretty sure your right but my car and every other si i've driven makes a light tapping sound at idle.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdm_dc_fan »</TD></TR><TR><TD CLASS="quote">thats wierd my girlfriends car does the same thing it makes tapping sound</TD></TR></TABLE>
pretty much every Honda 4cyl engine [and every smaller 4 cyl regardless of manufacturer] I have ever heard has a slight tick to it.
Koko4
Apr 26, 2015 04:05 AM
eap
Jan 18, 2009 11:44 AM
.MilanoRex
13
Sep 15, 2003 06:20 PM
