My b16a2 NA setup
Old May 17, 2008 | 11:29 AM
Noobsauce's Avatar
Default My b16a2 NA setup
Ok guys so I have been part collecting for a bit now and I'm just wondering where I should go from here. As of now I have sitting in my house skunk2 valves retainers and springs, toda timing belt, skunk2 pro+2 cams and cam gears. And installed on my car I have a DC header, T1R B-pipe to a spoon axle back a no name test pipe and an aebs intake manifold and also an exedy stage1 clutch and act 9.5lb flywheel. I know this is alot to read but I feel it will help answer my questions better. I'm looking to get the cams and everything *in my house* put in soon. Do I need to upgrade my fuel system to run this stuff properly or will it just give me a lil more power than normal if I do? I was also wondering if I need to upgrade my ecu or will running a stock one do the job unless I want more tunability? BTW I plan on upgrading my header to a tri-y or toda... Just something with more flow. Another question I have is what kind of power *dyno tuned* will I be looking at here? Thank you so much for any answers!
Old May 17, 2008 | 01:01 PM
Noobsauce's Avatar
Default Re: My b16a2 NA setup (Noobsauce)
Bump. Somone has to have done something close to this lol!!
Old May 18, 2008 | 08:32 AM
Noobsauce's Avatar
Bump...Nobody has done anything close?
Old May 18, 2008 | 11:41 AM
PHDM-EK's Avatar
Hmm.. you need to get a tunable ecu to maximize everything. Stock injectors/pump would be fine. No plans of bumping up compression?
Old May 18, 2008 | 03:10 PM
Noobsauce's Avatar
Default Re: My b16a2 NA setup (PHDM-EK)
Not yet atleast, thanks for the reply! I think I found a place to do some work for me also.
mattvivsound
Jan 12, 2019 02:26 PM
Baddawg1991
23
Aug 18, 2015 02:53 PM
Project_EK
10
Feb 25, 2007 12:21 PM
totsie7944
Dec 13, 2005 02:42 PM
guymosiris
Sep 21, 2003 08:15 AM
