tri-y into crx WITH crossmember.
Old May 17, 2008 | 09:47 AM
redsolturbo's Avatar
Default tri-y into crx WITH crossmember.
just finished installing my tri-y onto my B20-vtec ef crx.
going to wait until i change the rads next week to box section the cross member.
anyway pics for ya:
Old May 17, 2008 | 09:53 AM
ptftw's Avatar
Default Re: tri-y into crx WITH crossmember. (redsolturbo)
looks good man!
Old May 17, 2008 | 10:26 AM
0c00l's Avatar
Very nice indeed! I remember the first post when you got this car, at least I think it was you.
Old May 17, 2008 | 10:53 AM
Default Re: (0c00l)
yes it was me.
got my spray gun on order, still trying to figure out what color to do it, but it only made 185 flywheel hp/ 145lb./ft after mapping, mainly because the cams duration and lift are to short, also that ebay 2 inch nasty *** header are really holding back the numbers. its a TDM header btw, i jsut had the extra o2 bosses welded in and had the slip connection welded also. (they always leak lol)
CTR cams are sat here on my desk, shooting for 190-200whp with a good mid range.
just need her finished before the end of august as its the biggest crx owners meet here in the uk.
Old May 17, 2008 | 03:41 PM
Wilky's Avatar
Default Re: (redsolturbo)
I guess I will be the first to ask:
Why not get an aftermarket crossmember? Several good options out there.
Old May 18, 2008 | 02:29 AM
Default Re: (Wilky)
no nne make aftermarket members over here
Old May 18, 2008 | 09:16 AM
grog's Avatar
that cut in the crossmember looks like and accident waiting to happen
Make sure you weld in some good reinforcements to that crossmember I have heard of plenty of notched crossmembers folded/snapping.
and regaurding aftermarket traction bars, maybe nobody makes them, but couldn't there be somebody that stocks/sell them near you?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by redsolturbo &raquo;</TD></TR><TR><TD CLASS="quote">going to wait until i change the rads next week to box section the cross member.</TD></TR></TABLE>
edit: I guess thats what you meant here
Old May 18, 2008 | 11:16 AM
eviled's Avatar
Default Re: tri-y into crx WITH crossmember. (grog)
SiR crossmember is different to the Si crossmember, different mounting locations
the ETD might wokr as it bolts to the front tow hooks are the same but rumours of different radius arm angles and lengths are enough to put anyone off buying one to find out
CRX EF 88
Jan 31, 2008 05:32 PM
CRX_RUS
May 7, 2005 09:26 AM
midorigreen.
Oct 12, 2004 12:59 PM
orangetyper
Jul 7, 2003 10:52 PM
raene
36
Sep 5, 2002 11:13 PM
