Changed spark plugs, found oil
I changed my plugs last night, while changing going from right to left my 2nd valve from the right had oil in it, had a little white smoke when I started then went away of course. Nothing to bad.
Just wanted to make sure, too fix this fix the valve covers correct?
easy enough job
Also I have a 1990 crx si stock 1.6 engine
After I get the answer go ahead and lock this "toad"
thx to all
easy enough jobAlso I have a 1990 crx si stock 1.6 engine
thx to all
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ~sp33~ »</TD></TR><TR><TD CLASS="quote">I think by valve you meant spark plug. Change out the rubber rings that prevent the oil from getting into the chambers and you should be sweet.</TD></TR></TABLE>
Just pick up a valve cover gasket "kit" and it will have all you need.
i had the same thing yester day is ur oil on the top of the plug, cuz mines is on the bottom, makeing me think its a bigger problem like my piston rings...
also i got a misfire code do u think this is the cause
I found the same thing a while ago. Bought a valve cover gasket set and changed all gaskets and problem solved. I think there called the "tower seals" I could be wrong
I was having the same problem on 2 spark plugs on my crx, I was running redline sythetic at 185,000 miles. It was hard on the piston rings, so I switched back to regular oil and went away, drove it with regular oil for 10,000 miles with no oil at the bottom.
Then while it was parked a stupid drivier hit it and totaled it out after having for 2 1/2 years and 3,750 spent on it.
JDM-EJ1
15
Nov 17, 2004 05:32 PM
93FastLs
12
Oct 10, 2004 08:44 PM
