Which ECU with B16A2 Motor in 96 Civic?
Old Jul 15, 2002 | 01:56 AM
Unjockable's Avatar
New User
Default Which ECU with B16A2 Motor in 96 Civic?
Which ECU would I need to run good?
[Modified by Unjockable, 10:57 AM 7/15/2002]
Old Jul 15, 2002 | 02:48 AM
kenji's Avatar
Default Re: Which ECU with B16A2 Motor in 96 Civic? (Unjockable)
If you are willing to convert to OBD1 I stock chipped P28 ECUs that will run your setup real well.
I can make you the harness you need to convert to OBD1.
A lot of other users on this board are running my ECU and are quite happy with it.
Email me if you are interested. Thanks.
-kenji
Old Jul 15, 2002 | 11:55 AM
Unjockable's Avatar
New User
Default Re: Which ECU with B16A2 Motor in 96 Civic? (kenji)
you got mail.
Old Jul 15, 2002 | 02:57 PM
Jackson's Avatar
If you dont want to deal with all that ecu chipping stuff and want to stay obd2, get either a jdm p30 or jdm p73 ecu.
Old Jul 15, 2002 | 11:13 PM
Unjockable's Avatar
New User
Default Re: Which ECU with B16A2 Motor in 96 Civic? (Jedi Master)
yeah, I kinda want to stay OBD2. Where can I get those ECU? Which ECUs are they? (From which car/motor)
Old Jul 16, 2002 | 01:04 AM
Kamin's Avatar
p30 is obd I
p73 is from the JDM ITR
i hope you mean a REAL B16a2. not a jdm motor.
like b16a2 from the 99+ si
then just get that ecu. will save you alot of headaches.
Old Jul 16, 2002 | 10:38 AM
Jackson's Avatar
Default Re: Which ECU with B16A2 Motor in 96 Civic? (KAMiN)
p30 is obd I
Thanks for the clarification.
Old Jul 16, 2002 | 11:21 AM
Unjockable's Avatar
New User
yeah, I have a 2000 SI B16A2 motor. hope you guys know that the 99-00 SI ECU doesn't plug into my harness. I tried but it won't fit. I'm using a GSR OBDII ECU right now.
Old Jul 16, 2002 | 11:32 AM
Jackson's Avatar
Get an obd2 b16a ecu from either a jdm or usdm car. Jdm for less hassle with o2 and ckf sensor. Or you can run any jdm itr ecu or a 97-98 usdm itr ecu. Unless you want to go obd1, get an ecu jumper. We cant spoon feed you information on what to do, its your car, you have plenty of choices.
Old Jul 16, 2002 | 12:11 PM
BoOsTeD_eK's Avatar
I have a JDM b16a2 ecu...$225 shipped.
Old Jul 16, 2002 | 12:17 PM
Unjockable's Avatar
New User
thanks for the infos.
Old Jul 16, 2002 | 08:00 PM
CRAYZBOYZS's Avatar
JDM dont have OBD2 HELLO
CRAYZBOYZS's Avatar
are jedi master bullshit?
Old Jul 16, 2002 | 09:13 PM
Jackson's Avatar
Default Re: Which ECU with B16A2 Motor in 96 Civic? (CRAYZBOYZS)
If you want to be a smartass, do it in the shithole town you live in. OBD2 as in the plugs.
Old Jul 16, 2002 | 11:00 PM
Kamin's Avatar
retard
jdm/usdm plugs are the same, and they have OBD over there its just no emission controls
[Modified by KAMiN, 12:01 AM 7/17/2002]
Najdmitr307
Engine Management and Tuning
10
Mar 10, 2009 03:18 PM
BrandonB16
Feb 17, 2009 05:33 AM
r1ynb
Jan 8, 2007 07:08 AM
LpBoy2004
Feb 13, 2004 11:16 PM
totaled
32
Aug 17, 2003 09:30 AM
