Disconnecting ABS wires on a 95 EX?
Alright, I need to change the rear trailing arm and the ABS wires is connected to what I think is called the brake knuckle. So how should I go about removing this? I also need to do it because I need to get the LCA off and it's ran across the LCA and under the strut. Any advise would help. Thanks in advance.
JDMRice
Mar 10, 2007 06:18 AM
