What are signs of needing a Valve Adjustment?
Old May 16, 2008 | 08:46 PM
DOHC Kid's Avatar
Default What are signs of needing a Valve Adjustment?
As stated above, what are some signs that tells you you need to get your valves adjusted?
I have a bad idle problem and trying to figure it out. IAVC is clean, TB, Cleaned. Maybe valves needed to be adjusted? I hear a lot of air. No vacumm leak either.
Old May 16, 2008 | 08:51 PM
mr.beeks's Avatar
Default Re: What are signs of needing a Valve Adjustment? (DOHC Kid)
loud ticking noises like the car had a diesel engine.
Old May 16, 2008 | 10:16 PM
all-mtr-teg's Avatar
Check you TPS and MAP sensors first. Then if those are good perform a valve adjustment. Its good to do one every several air filter changes or so, specially if you have aftermarket cams. I do mine every 12-15k miles now. The first time I installed aftermarket cams on my DD, I waited almost 20k miles to do a valve adjustment, several were at .011 IN and a few at .010" EX. That explained the loud ticking
Old May 17, 2008 | 08:32 AM
Jdm_jay's Avatar
valvle adjustments are usually noticed as ticking noise. or even if your car has a loss power or gas milage goes a lil bit. but your problem is not the valves even tho u should probally adjust them if you havent.
Old May 17, 2008 | 08:57 AM
FuNkDrSpOt's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DOHC Kid &raquo;</TD></TR><TR><TD CLASS="quote">As stated above, what are some signs that tells you you need to get your valves adjusted?
I have a bad idle problem and trying to figure it out. IAVC is clean, TB, Cleaned. Maybe valves needed to be adjusted? I hear a lot of air. No vacumm leak either.</TD></TR></TABLE>
The #1 tell-tale sign that you need a valve adjustment? Mileage. Just adjust it every 65k-90k miles and you should be fine.
Old May 17, 2008 | 08:59 AM
FuNkDrSpOt's Avatar
Default Re: What are signs of needing a Valve Adjustment? (all-mtr-teg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by all-mtr-teg &raquo;</TD></TR><TR><TD CLASS="quote">Check you TPS and MAP sensors first. Then if those are good perform a valve adjustment. Its good to do one every several air filter changes or so, specially if you have aftermarket cams. I do mine every 12-15k miles now. The first time I installed aftermarket cams on my DD, I waited almost 20k miles to do a valve adjustment, several were at .011 IN and a few at .010" EX. That explained the loud ticking</TD></TR></TABLE>
Seems excessive. I mean it's not hard to just measure the clearance, but do you actually end up having to REALLY adjust valves every 12-15k? How aggressive are your cams?
Seems like your valves are just begging to drop.
Old May 17, 2008 | 10:23 AM
Rickdrizzle's Avatar
I just adjusted my valves today... in the damn sun. Central california heat FTL.
Old May 17, 2008 | 11:50 AM
Default Re: (Rickdrizzle)
Did mine last night in my garage at 10:00 P.M. was still like 85 degrees F in there with a fan and the garage doors open.
Old May 17, 2008 | 11:52 AM
Default Re: What are signs of needing a Valve Adjustment? (FuNkDrSpOt)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FuNkDrSpOt &raquo;</TD></TR><TR><TD CLASS="quote">
Seems like your valves are just begging to drop.</TD></TR></TABLE>
I check them often, Blox B cams, really agressive driving 150-200 miles a weekend Most of the time only a few need adjustment
Old May 17, 2008 | 12:16 PM
PM, replied
Old May 17, 2008 | 01:46 PM
FuNkDrSpOt's Avatar
I check them often, Blox B cams, really agressive driving 150-200 miles a weekend Most of the time only a few need adjustment </TD></TR></TABLE>
So let me ask you guys who do the adjustments. If it says something like .006 - .008, does that mean that if i want to adjust it to .007, then .008 shouldn't even be able to fit in the crack? Or will .008 fit but be REALLY snug?
The only thing i don't get about doing a valve adjustment is how much 'drag' the gauge should feel when being slid in and out.
jond
Acura NSX
Jan 4, 2008 08:21 AM
Peruviann83
Mar 30, 2007 10:10 AM
XenonDepot
Apr 18, 2003 12:44 AM
lilxvtecxpwr
11
Sep 17, 2002 05:58 PM
ken
Sep 25, 2001 04:06 AM
