Losing Prime in fuel system
Old May 16, 2008 | 06:48 PM
jtmoney2002's Avatar
Default Losing Prime in fuel system
Ok, i have an 88 crx with d16a6 in it, mostly stock. Fuel pressure gauge and adjustable fuel regulator, plugs wires. Reason i put the reg and the gauge on there to see what i was running..40 while runiing.but anyways after the car sits for i while the psi drops to 0. and from my understanding is that it should keep some pressure in the line. Takes about three to four cranks to start it after its been sitting 8 hours or so. so u guys thinks its injectors or fuel pump or neither.?? thanks Jt
Old May 17, 2008 | 03:07 PM
blkb18's Avatar
Default Re: Losing Prime in fuel system (jtmoney2002)
Maybe the regulator is leaking back through the return line to the tank. Try pinching off the return line after you shut it off, then see if the guage holds over time.
Old May 17, 2008 | 05:52 PM
Default Re: Losing Prime in fuel system (blkb18)
will do, trying some good injector cleaner now, thinking maybe injector is sticking open draining it down on my piston and maybe thats why its losing prime. But it may be the reg as u said but will do after this experiment lol thanks
attack666
Dec 3, 2010 06:53 AM
95streetciv
Mar 13, 2009 07:20 AM
-[95cxhatch]-
Jul 11, 2008 09:27 PM
-[95cxhatch]-
18
Jul 11, 2008 02:29 PM
baby50
Feb 26, 2006 02:13 PM
