Electrical nightmare
Hey all,
I have a 1990 CRX Si with a strange problem. When I turn my headlights on, it causes my brake lights to light up and they stay on. So when I'm driving down the road with my headlights on it looks like I'm stepping on the brake the whole time. Now when my headlights are off my brake lights come on when i step on the brake, but when i do hit the brake my dash lights up like it would if i turned on my headlights. The taillights leak so water get in there on the wires I dunno if maybe the water caused a short or something. I'm going to pick up some new taillight gaskets and see if that solves the leak. Anybody know whats goin on?
i bet you one of your running/brake light bulbs blew and fused the filiment together making one circuit. it happened to me
check and replace it or to be sure find the blown one and see if the rest of the lights work ok with it removed.
matter of fact, one of the bulbs is actually blown, I'll have to buy a replacement bulb. So if i replace it my problem may be solved?
It definately sounds like some crossed wires. trace the brake light switch wires and look for where they cross. the brake switch is located on the pedal assembly.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sixgunsound »</TD></TR><TR><TD CLASS="quote">matter of fact, one of the bulbs is actually blown, I'll have to buy a replacement bulb. So if i replace it my problem may be solved?</TD></TR></TABLE>
yes may be solved but just remove it and see if the rest of the lights work
When I take the bulb out it dosent change anything. Also when I step on my brake the corner headlights come on. I'm thinkin im in for some serious work here.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sixgunsound »</TD></TR><TR><TD CLASS="quote">When I take the bulb out it dosent change anything. Also when I step on my brake the corner headlights come on. I'm thinkin im in for some serious work here.</TD></TR></TABLE>
do u have a single element bulb in a dual element socket?
also check all of the bulbs it might not seem blown but it could have fused the elements together. remove the bulbs in the rear except the third brake light. then turn on the headlights and see what happens to the third brake light
it sounds like your parking lights are back-feeding the brake lights and vice versa. the problem is definitely in the rear of the car. it is possible that one wrong bulb back there could cause this. i'd check/replace all 4 of the main taillight bulbs
I do have a singal element bulb in a dual socket. One of my lights went out and ibought one at the hardware store but didnt know till after it wasent the exact same as the one that came out. I'll get the right one and see if it works.
Thanks for all your help guys.
Ok so I switched the one bulb that was only a singal element. That solves my original problem but now when I hit the brakes with the headlights on the left rear headlight goes out but the brake light comes on. I'm quite confused.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by grog »</TD></TR><TR><TD CLASS="quote">are you sure you found all the single element bulbs?</TD></TR></TABLE>
like grog said check and see if you found them all. replace all of the bulbs just to be on the safe side.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sixgunsound »</TD></TR><TR><TD CLASS="quote">That solves my original problem but now when I hit the brakes with the headlights on the<U> left rear headlight </U>goes out but the brake light comes on. I'm quite confused.</TD></TR></TABLE>
lol...I've never heard of ^^ a rear headlight...lol
G0crxG0
Jul 25, 2012 05:30 AM
fourlug
May 7, 2011 01:46 PM
Cosworth2009
Dec 27, 2008 10:04 PM
