How much will a 4.9 final drive help???
I'am building up a n/a d16z6 in my ej1. My goal is ~150-160whp and with that little hp I know gearing can make or break you. I did a little messing around with the fatboy raceworks calculator and saw that going from a 4.25 final to 4.9 will do the following in comparison...
4.9
1/4 mile on 20" slicks
traps at 7500rpms if ~100mph
4.25
traps at 6500rpms if ~100mph
4.9
205/50-15 tires
cruise at 2550rpms at 50
cruise at 3500rpms at 70
4.25
205/50-15 tires
cruise at 2200rpms at 50
cruise at 3050rpms at 70
I guess my questions is...
Can a higher final drive give me a couple tenths more in the quarter? how much difference will this make in my mpgs?
4.9
4.25
4.9
205/50-15 tires
4.25
205/50-15 tires
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wfocrx »</TD></TR><TR><TD CLASS="quote">also, is high 13's possible in a ej1 with 160whp+gearing+traction</TD></TR></TABLE>
it is very possible.
on 20's, a 4.9 may or may not require 5th gear in the quarter mile, it will definatley make your car faster, but if it requires 5th, then I'd go lower on the f/d
with my 4.9 ats final drive with ats 1st gear 3.077, bseries build though, i'd end up top 4th and saving the shift to fifth saves a lil time, oh by the way my car is a daily driver, gas is gonna be a killer
Most people report getting better gas mileage with the higher FDs, myself included, due to having to use less throttle input when accelerating. Throttle position seems to have a greater effect on fuel consumption than RPM.
Bense
Sep 29, 2006 12:14 PM
OK
Dec 3, 2001 05:06 PM
