1997 Accord Leaky Sunroof
Old May 16, 2008 | 09:33 AM
JDMRedH's Avatar
Default 1997 Accord Leaky Sunroof
Quick question, my friend has a 1997 Accord and the sunroof leaks really bad all over the inside of the car. Is this a common problem on these Accords? Do you just have to replace the weather stripping around the sunroof to fix the problem? Thanks.
Old May 16, 2008 | 03:06 PM
hondadude's Avatar
Default Re: 1997 Accord Leaky Sunroof (JDMRedH)
If it is a factory sunroof [Ex model] the most common problem is plugged up sunroof drains.
The drains have a little rubber 'duckbill' on the end of them to prevent bugs from crawling up in there and nesting. Chop off about 1/2" of that duckbill.
To get to the front drains remove the mudflap behind the front wheels and the lower 5-6 screws holding the fender liner in place. Then look behind the liner for a hose
The rear sunroof drains are accessed thru the trunk liners on each side.
Remove the plastic retaining clips to get in behind the liner and again follow the hose to get it loose and cleaned out.
Old May 17, 2008 | 06:55 AM
JDMRedH's Avatar
Default Re: 1997 Accord Leaky Sunroof (hondadude)
Thanks man
Njvsvalhalla
Sep 15, 2018 03:20 PM
bakkouz
Oct 2, 2015 11:27 AM
nikkijohnson123
Feb 16, 2015 04:48 AM
Jpluck09
Jan 12, 2009 02:41 PM
@ck
Dec 4, 2007 10:30 AM
