i;m afraid to even ask....head gasket diagnosing
Old May 16, 2008 | 07:28 AM
danteisme's Avatar
Loved
Community Favorite
Default i;m afraid to even ask....head gasket diagnosing
i know most of the common ways to tell if a head gasket is blown. what are all the signs of a blown headgasket? i wanna make sure i'm not missing anything. whats a sure-fire way to tell if it is?
Old May 16, 2008 | 08:32 AM
VerbalVenom's Avatar
Default Re: i;m afraid to even ask....head gasket diagnosing (danteisme)
Fire the car up with rad cap off and look for bubbles. Pull out dipstick and check for murky color or antifreeze/water and oil mixture. You could also do a leakdown test on each cylinder and whichever one fails is where you're problem exists. Smoking white smoke is another tell tale sign. Run your heat, if you smell antifreeze that's another sign. Another sign is you'll be losing coolant. I think that's about it..
Modified by VerbalVenom at 12:44 PM 5/16/2008
Old May 16, 2008 | 08:42 AM
all-mtr-teg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by danteisme &raquo;</TD></TR><TR><TD CLASS="quote">i know most of the common ways to tell if a head gasket is blown. what are all the signs of a blown headgasket? i wanna make sure i'm not missing anything. whats a sure-fire way to tell if it is?</TD></TR></TABLE>
Pull the head off and check the head gasket.
Old May 16, 2008 | 08:45 AM
Default Re: i;m afraid to even ask....head gasket diagnosing (all-mtr-teg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by all-mtr-teg &raquo;</TD></TR><TR><TD CLASS="quote">
Pull the head off and check the head gasket.</TD></TR></TABLE>
QFT!
Old May 16, 2008 | 11:22 AM
super jdm yo's Avatar
Default Re: i;m afraid to even ask....head gasket diagnosing (VerbalVenom)
you can just look at the bottom of the oil cap and see if there's like a white haze, that'll tell you if water's gotten into your oil. and see if you're losing coolant
Old May 16, 2008 | 04:38 PM
I has a Teg's Avatar
Default Re: i;m afraid to even ask....head gasket diagnosing (super jdm yo)
i found out mine was bad simply by pulling out the plugs and smelling them. i smelled antifreeze. lo and behold, it was a bad head gasket lol. give that a shot and if you smell antifreeze, it'd be pretty safe to say yours is bad just like mine was. hope this helps.
h3rsh3y2001
Nov 15, 2008 12:37 AM
zcmotor
29
Apr 18, 2008 10:20 AM
oakraidersnum1
Mar 9, 2008 01:53 PM
4theluvofhonda
15
Jan 21, 2007 05:00 PM
racingfan
Sep 3, 2006 11:27 AM
