GSR Build Need Help
I plan on building a gsr and I wanted to know if I'm on the right path so far.
Gsr block
B20 crank
JE 12.1:1 pistons
ported gsr head
chipped p28
type r cams ( jdm of course )
b16 or gsr trans
83 mm bore darton sleeves
skunk2 intake manifold
70 mm throttle body
8 lbs. flywheel
act clutch
msd complete ignition system
I think that's it. Let me know of anything that I can improve on. All input is welcome I really want to do this right the first time.
Gsr block
B20 crank
JE 12.1:1 pistons
ported gsr head
chipped p28
b16 or gsr trans
70 mm throttle body
8 lbs. flywheel
act clutch
I might have a chang in plans. I might be getting a b16 block with ls crank and ls rods. But I need to know if this will work.
use this, http://www.zealautowerks.com
Plug in the b16a block, ls rods and crank and whatever pistons you plan on using, then tell me you want to build a motor with the compression ratio calculated. Your cousin is a moron. I'll give you a hint, deck height
Also, I pm'ed you, check it out.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90blkteg »</TD></TR><TR><TD CLASS="quote">Why wouldn't it work for a b16a? My cousin said that it would work.</TD></TR></TABLE>
stick around you will learn a few thing here in HT..
but you are not stating your goals you are just naming parts
anybody could do that.
tell us your goals and we could help you out better.
PS were is fuel management in the pic? with out it ]u just got a bucket of junk.....
Decked how much? If its a B16a block, that just compounds the problem.
Since you obviously didn't use the link I previously gave you, here's another hint, does "piston to head clearance" mean anything to you or your cousin?
Modified by all-mtr-teg at 3:49 PM 5/20/2008
I don't know how much it is decked but I'm going to see the block on monday. The guy that currently owns the block was going to build it to put it in an ek hatch. I haven't talked to him yet to see exactly what direction he was planning on taking the build. Even if this isn't the right block for me I still have the option of getting the gsr block. Also I read last night that there is a special piston kit that allows you to do the setup that I want to do with the b16.
Yes I see why. So since he decked the block how can I measure it to make sure the block has been decked to the correct specs? The block has no pistons in it as of now.
punkassazn
Apr 19, 2005 03:52 PM
ok i got my b16a block gsr crank,ls rods what to bore my motor to .25 are more? an what pistons to u
gulf imports
Jun 20, 2004 06:35 PM
Irishweird00
11
Jun 5, 2003 06:51 PM
