turboed h23 with a problem
Old May 16, 2008 | 05:01 AM
Pman92's Avatar
Default turboed h23 with a problem
Hi all. I have a 92 h23 prelude turbo with an issue. I blew the head gasket and since then it has been fixed. Put new head gasket in and did a compression test and came accross 180, 180, 120, 180. We did a leak down test and air was blowing by the #3 rings. Pulled the engine back out and the rings were compressed around the piston. Looked like there was some build up in the ringland area. These are Arias turbo pistons by the way with a darton sleeved block. Cleaned the ringlands out and put new rings on it. Put the engine back together after rehone and new rod bearings. Did a compression test again and 180,180,150,180 again #3 cylinder. Did a leak down test and its leaking passed the spark plug hole. I mean blowing air just straight back up. I put some silicone around the bottom of my compression tester and it jumped right up to 180 on # 3 cylinder. Has anyone else had this happen to them or am I missing something here. Pulled the head back off and the threads look fine. Thinking of having an insert put in just want to now what anyone else thinks.
Thanks Pat.
Old May 16, 2008 | 05:08 AM
1fastlude1's Avatar
Default Re: turboed h23 with a problem (Pman92)
are u sure the o ring on the gauge line was tight when u did the test, how does the threads on the plug look
Old May 16, 2008 | 05:27 AM
Pman92's Avatar
Threads look fine and no problems with gauge on other 3 cylinders either. Just #3.
Old May 16, 2008 | 11:10 AM
Pman92's Avatar
anyone else
aaronTL
Feb 18, 2013 08:53 AM
straightshot08
Feb 23, 2009 05:20 PM
m00nr0ck Si
Aug 9, 2008 05:27 AM
LudeyKrus
Nov 7, 2002 09:44 PM
