weird clutch pedal problem???
Old May 15, 2008 | 06:08 PM
beatthisspeed69's Avatar
Default weird clutch pedal problem???
so i put a b16 tranny on my b16a about a month ago had a ls trans on there,so the tranny was all good except for 3rd gear being out i got ripped off lol,,well i had a stoc p28 in it and it only went to 7300 its it shifted perfect now i have a chipped p28 and now it goes to 8300 and now wen i take it all the way to 8300 my clutch pedal will get stuck to the floor and will stay like that until i pick it up with my feet...so why is it doin that if i shift at low rpm's it wont do it but high it will do it...do you think it is my throw out bearing goin out or wat..any help will be appreiciated
Old May 15, 2008 | 06:34 PM
ne1?
Old May 15, 2008 | 06:43 PM
90_EX_Civic's Avatar
Default Re: weird clutch pedal problem??? (beatthisspeed69)
vacuum leak?
edit* my bad, was thinking brakes when i said this. but im leaning more towards your clutch master, maybe even the clutch piston ( the part that pushes the arm for the throw out bearing). ether that or have you checked out the pedal assembly?
Old May 15, 2008 | 07:45 PM
oh forgot to mention its a cable transmission..dont think its the pedal assembley cuz it never had this problem b4 and it looks good
Old May 15, 2008 | 08:44 PM
ne body else
Old May 15, 2008 | 09:49 PM
MugenGTR
Jan 29, 2012 02:14 PM
midnitesol
Transmission & Drivetrain
Nov 24, 2010 05:57 PM
notstock93
Jan 14, 2005 03:24 PM
argosyinflames
Feb 22, 2004 08:21 PM
Chip398193
Aug 31, 2001 03:54 AM
