Parts needed for a JDM B18C GSR swap
Hello everyone,
Just got me a JDM B18C motor; I was wondering what parts i would need to purchase to do a swap into a 92 4dr teg. The motor is obd2, I believe and is equipped with the hydro-tranny. Any help would be greatly appreciated. Is there a link or a website that will tell me ALL parts needed for the swap? I dont want to buy new parts if I could reuse from the old B18A1.
I've been told that i could use and is recommended to swap over to the JDM B18C engine due to the difference in obd system; the following from the old motor could be use:
-axles
-engine harness
-injectors
-distributor
-obtained USDM B18C1 ecu
-motor mounts????? not sure about this due to the difference in transmission; my new motor is hydro (may need a hydro>cable kit)
-shift linkage
-radiator
Please list out what new parts i need to purchase.
Please correct me if if I'm wrong or PLEASE add to the list. This is my first solo-swap and I want to make sure I have EVERYTHING before I begin. Thanks in advance.
-axles
-engine harness
-injectors
-distributor
-shift linkage
-radiator
honestly for that much wrenchtime and cash, i'd trade in that 4dr and but a newer GSR. it'd end up being cheaper. then just use the cash you saved to convert to JDM if you so please
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmnovice-21 »</TD></TR><TR><TD CLASS="quote">Hello everyone,
-axles
-engine harness
-injectors
-distributor
-shift linkage
-radiator
On the distributor you have to chop off the leg. Because it won't fit properly or if you don't want to do that you can buy a 92-93 OBD-1 GSR distributor. Make sure to buy engine oil, transmission oil, radiator fluid,
-axles
-engine harness
-injectors
-distributor
-shift linkage
-radiator
richardb53
Jan 24, 2006 01:59 PM
