Rear Brake Disc Stuck On- Any Ideas how to get it off?
Old May 15, 2008 | 03:03 PM
MrDomino's Avatar
Default Rear Brake Disc Stuck On- Any Ideas how to get it off?
I'm replacing the brake discs and pads on my GSR and the rear brake disc is stuck to the hub. I've been beating on it with a hammer for about 3 hours now. I've been coating it in PB Blaster and even tried heating it up but it won't budge. I also tried putting bolts through the disc to push it from the hub.
Anyone have any ideas on how to get it off? Thanks.
Old May 15, 2008 | 03:17 PM
Dogginator's Avatar
Daisy... Daisy...
Default Re: Rear Brake Disc Stuck On- Any Ideas how to get it off? (MrDomino)
Did you remove the two rotor screws?
Use a BFH to hit the bottom of the rotor outwards. Hit it hard and the rotor should fly. I use a 3lb dead blow hammer.
Old May 15, 2008 | 03:42 PM
MrDomino's Avatar
After a fit of rage with a rubber mallet it popped right off...
honvic
Suspension & Brakes
14
Mar 12, 2012 01:46 PM
Cincinnatux
Oct 4, 2009 10:39 AM
joelmatt89
11
Mar 9, 2009 05:30 PM
CardDealer
Jul 25, 2006 09:14 AM
ken
Jul 3, 2002 08:00 PM
