rear motor mount on EG
Old May 15, 2008 | 02:35 PM
gsrpedro's Avatar
Default rear motor mount on EG
i have a hatch wit a gsr motor and my rear motor mount its fukd up i have a question can i use the rear mount from the dc integra or i have to use the stock one? thanks
Old May 15, 2008 | 03:23 PM
superfast666's Avatar
Default Re: rear motor mount on EG (gsrpedro)
yes
Old May 15, 2008 | 03:27 PM
BryanM.'s Avatar
Resident Gearhead
Default Re: rear motor mount on EG (superfast666)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by superfast666 &raquo;</TD></TR><TR><TD CLASS="quote">yes</TD></TR></TABLE>
yes
yes
Old May 15, 2008 | 03:36 PM
JUNKIE DUCKY's Avatar
Default Re: rear motor mount on EG (mcvtec)
yes and you gotta use the bracket too
Old May 16, 2008 | 07:34 PM
gsrpedro's Avatar
yes for the stock or dc??? i know i already had the motor in but the motor mount its fkd up i need a new plus i just install a stage 4 clutch and 8lbs flywheel..
Old May 19, 2008 | 08:15 AM
Default Re: (gsrpedro)
is the same motor mount dc engine bay is the exact same engine bay as the eg everything is the same you can mix and match parts
Old May 20, 2008 | 10:40 AM
gsrpedro's Avatar
Default Re: (JUNKIE DUCKY)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JUNKIE DUCKY &raquo;</TD></TR><TR><TD CLASS="quote">is the same motor mount dc engine bay is the exact same engine bay as the eg everything is the same you can mix and match parts</TD></TR></TABLE> thank u
b18b1ef8
Apr 19, 2008 08:34 PM
GranadaTeg
May 11, 2006 10:52 PM
joedubovik
Nov 3, 2005 07:30 PM
eg6r4eva
15
Feb 12, 2005 02:00 PM
RacerSi
Nov 17, 2003 02:42 PM
