brake issues. newly built car. need some good minds to help me out plz
ok so i just finished building my eg w/ DC2 f & r brakes. new brembo disc, hawk HPS pads, SS lines, Motul RBF 600 Racing Brake Fluid, 40/40 PV, brake booster, 15/16s MC. test driving around it's fine. brakes work awesome! but after 5 mins of driving they start sezing up to the point where i'm fully boosed at 4000RPMs and not moving and the clutch starts to slip. so i have to wait an hour to let the brakes cool down then it's fine. for another 5 mins. the vac line is on w/ the valve w/ the E pointing towards the motor. PLZ help me out.
You probably need to adjust the push rod to the booster and the MC. If it isn't fully releasing, it can progressively lock the brakes.
what brake booster are you running?
you CANNOT run a abs booster with a non abs MC will not work with each other
http://www.team-integra.net/fo...08331
idk about that. i think it's the the 15/16 MC is longer so when i mate it up to the ABS BB it presses a lil. i will work on it tomarrow and see what i come up with. if all i have to do is shim the MC, cool i'm down
Ohannon7
Feb 20, 2020 12:05 AM
b16mario
13
Aug 11, 2014 06:09 AM
YELLOW_DUCK
13
May 18, 2008 01:50 PM
