Picked up 99-00 SI brakes need to info on additional parts need to complete the swap
Yesterday picked up a 99-00 SI brake swap front and back, but now need further information on additional parts needed to complete this swap.
I have a 90 SI hatch right now. I need to know the following:
Can I keep my stock brake booster?
Do i need to upgrade my MC? If so what should i get that would fit?
Prop valve do i need a 35/40 or 40/40 ? If i get a new prop valve to i have to change the fittings on the hard lines?
Anything else that I am missing.
I plan on doing this swap, change bushings and put some extended wheel studs.
Please let me know.
Thanks.
Please let me know.
Thanks.
1. Sure you can keep your stock BB.
2. I would definitely upgrade to a Bigger MC (90-93 Integra NON-ABS) to get the full potential out of the bigger front nrakes you now have. Also, if you do end up upgrading your MC, I would might as well upgrade the BB too.
3. When I did my brake swap on my CRX, I used the 90-91 CRX Si prop valve. No need to bend or re-fit lines, perfect fit.
Thanks again Robert, hope you enjoy your bigger brakes and rear discs, I know I don't regret ever doing it.
